    Logitech F710 and Home button...
    GamePad/GPIO/USB encoder
    logitech f710 home button
    • BlackHoleVR
      BlackHoleVR last edited by
      I using recalbox on Odroid XU4.
      My gamepad is logitech F710 and i have some questions / problem.
      1 - The gamepad work only in DirectInput mode. Why?
      2 - In DirectInput mode the home button (logitech button) not work. Why?
      Is there anyone to have the same gamepad?
      Tank you for your help...
      • tuxophil
        tuxophil last edited by
        Hi, I'm using 2 Logitech F710 controllers. They work perfectly fine for me in XInput-Mode.
        The only slightly annoying aspect during initial controller setup is setting up the trigger buttons (L2 / R2):
        I have to configure the other buttons first, then use the dpad to select L2 again, then hit the physical B and then pull the left trigger. Afterwards I do the same to configure R2.
        Did you try reconnecting the USB dongle?
        For me the gamepads were/are working fine in recalbox 3.2.11 and 4.0-beta5, though I have to do the initial first-time setup.
          this a a known bug when L2 is a trigger. But you only need to configure your cnotroller once. The pad itself then known, which ever player it is set to
