    How can I set different controls for FBA?
    different controls fba
    • Kaervekkun
      Kaervekkun last edited by
      Hi.
      I wonder if there is a way to set up a different set of controls for FBA/other emulators. I tried to configure (through hotkey) a set of controls, but it doesn't load.
      My retroarch file content: http://pastebin.com/HdjArjSJ.
      My fba file content: http://pastebin.com/9JxppD6J.
      Thanks 🙂
        do you mean piFBA or fba_libretro ? The FBA standalone or the retroarch core ?
        • Kaervekkun
          FBA Libretro. About the second question, I'm not sure (I'm new configuring recalbox).
            if you're using fba_libretro it's the retroarch core.
            Here is a first step : https://github.com/recalbox/recalbox-os/wiki/How-to-use-custom-config-for-emulators-(EN)
            You can also have a look at core remap features. That's what i use for neogeo non my arcade stick. No wiki yet sadly. Open the retroarch menu, It's in Quick menu > controls. Remap from there, then save remap controls.
            • Kaervekkun
              I added the line to load my fba_libretro.cfg file, but it doesn't work.
              Also, I've tried to configure retroarch (I move through the menu using a keyboard), but when I try to map a button from the joystick, it doesn't recognise it. Do I need to press anything before trying to map it (Enter doesn't work).
              Thanks again.
