    PSX Emulator Compatibility
    Emulator Arcade/PC/Console
    psx compatibility
    8343
    • tonyloco
      tonyloco Translator last edited by tonyloco
      I started this Google Spreadsheet @Nachtgarm made a more detailed version of the list with PSX Compatibility for Recalbox where you can add your tests and sharing them with everybody. It's easy to understand, you can find:
      • Title (with Country)
      • Category
      • Raspberry Pi Version
      • And a space for notes
      If you use this list, please be sure you have the latest version of Recalbox!
      Please, check it out this link!
      Distracted and hyperactive gamer at Distrattivo
        Hello, humm FF games are playable in recalbox. But these games are protected, so you must to patch them. Google it, you will find many informations talking about .ipf patch or .sbi files.
        • tonyloco
          Thank you @rockaddicted, just added the info on the spreadsheet!
          • Nachtgarm
            Nachtgarm last edited by
            Having a list for PSX Games is a great Idea @tonyloco. I made a little more detailed version of it. Shall we use THIS ONE and spread it througout the community?
              paradadf Staff last edited by
              I haven't had one single psx not working on my overclocked RPi2... And I've tested a lot! I asked myself always if the problem lays on the power of the Pi, or just using a bad dump (or protected). For me, PSX works perfectly 😄
              • Nachtgarm
                Nachtgarm @paradadf last edited by
                @paradadf I had a few Games working with Major Issues as well. I mean... it isn't a bad think to have this list, is it? 😉
                  paradadf Staff @Nachtgarm last edited by
                  @Nachtgarm of course not... My list would be all green and working ok though XD
                  • Nachtgarm
                    @paradadf Well. Then start working in my list with marking the games 😉
                    • tonyloco
                      On my Overclocked RPi2, for example, FFVIII sometimes skips, but it's playable.
                      • tonyloco
                        Great idea for the list, @Nachtgarm. I just updated the thread!
                        • Nachtgarm
                          Nachtgarm @tonyloco last edited by Nachtgarm
                          @tonyloco Please add a note to your initial thread that, if people will use the list, they MUST make sure to be always on the latest version of recalbox. Otherwise we won't have any consistency.
