    4 Player Zero-Delay Encoder Setup Help
    GamePad/GPIO/USB encoder
    zero-delay dragonrise usb encoder
    4850
    • acidrs
      acidrs last edited by
      Hello,
      I am needing some help configuring a 4 player Zero-Delay Encoder setup.
      I have 4 Zero-Delay Encoders that are being displayed as Dragonrise Inc Encoders.
      lsusb lists each device
      BUS 001 Device 007: ID 0079:0006
      BUS 001 Device 009: ID 0079:0006
      BUS 001 Device 010: ID 0079:0006
      BUS 001 Device 011: ID 0079:0006
      I can go through Menu > Controller Settings > Configure a Controller and configure each encoder
      Under input P1 through P4 the only information i can see is
      #0 Dragonrise INC. ...ick
      #1 Dragonrise INC. ...ick
      #2 Dragonrise INC. ...ick
      #3 Dragonrise INC. ...ick
      When loading up an emulator for example Snes players 1 and 2 configurations go out of whack. As in the buttons configurations that were previously setup up dont stick. For example Player 2 A,B,X,Y buttons become split up over player 3 and 4 randomly .
      Arcade games through Mame or Flibretro has the same issue except player 3 seems to only be able to access the Emulator menu i.e take screenshots, access menu etc. This player cannot play a game.
      Can someone help me set this up correctly to identify each Player and configure each player to work across all emulators. I was thinking i need to manually set each players configuration in a file somewhere but i have no idea where to start.
      Any help will be greatly appreciated
        Hello
        can you type command line in ssh : /recalbox/scripts/recalbox-support.sh
        upload zip archive http://www.zippyshare.com/
        • acidrs
          Zippyshare link
          http://www65.zippyshare.com/v/aWYSDQE5/file.html
            i wonder if retroarch is not lost in all those pads ... 4 times the same one, no idea how it can sort everything out.
            Could you make a pastebin of #/configs/retroarch/retroarchcustom.cfg ?
            acidrs 1 Reply Last reply Reply Quote 0
            • acidrs
              acidrs @Substring last edited by
              @subs said in 4 Player Zero-Delay Encoder Setup Help:
              I think you are right. Need to find a way to define each pad with some type of identifier that will point the correct configuration to each one.
              Heres the pastebin
              http://pastebin.com/gP1RhAYu
                Substring @acidrs last edited by
                @acidrs give a try ti the sdl2 driver instead of udev. You have to edit the recalbox.conf. Can't remember the real name of the var, something like input.driver
                • acidrs
                  Ok ive changed to the sdl2 driver the var is
                  global.inputdriver=sdl2
                  Im going to do a fresh install as the system is giving me some funky behaviour after updating to the Recalbox 4 beta 5.
                  Selecting any game loads the wrong game, im also getting an issue where after loading a game the main emulationstation menu loads back up after a couple of seconds with the game still loaded in the background.
                  • digitaLumberjack
                    digitaLumberjack Staff last edited by digitaLumberjack
                    Did you modified anything in /etc/init.d ? Seems like your are having two emulationstation started ...
