    NES30 pro - B Button and Hotkey the same?!
    GamePad/GPIO/USB encoder
    nes30 button hotkey same
    4463
    • InpureD
      InpureD last edited by
      Hey there,
      I just bought a 8bitdo NES30 Pro to use it with my Raspberry PI with RecalboxOS. Now I got a problem. I have to configure the controller and I want to use the Connect Button as Hotkey, but everytime I wanna configure it, it assigns the 'B' Button as Button 1 and the Connect-Button also. So it's used twice. And of cause both doing the same. So everytime I press B the menu of the emulator opens up...
      What am I doing wrong? Is the controller faulty, or is it just not possible, to use the connect button as Hotkey?
      Already flashed it on different Firmwares... And also rebuild Recalbox OS... Also tried 4.0.0 beta 5... Same issue
      Sry for my bad english, but I hope you're able to read and understand it 😉
      Greets,
      Daniel
      • digitaLumberjack
        Use select or l3.
        • InpureD
          Ye, that should work, but I would like to use the Connect-Button....
          The strange thing is, that it worked, but after a few other problems and reinstalling recalbox the buttons mixed together...
          Maybe the controller is broken by flashing?!
          • digitaLumberjack
            Did not test the last firmware, i will take a look.
            • InpureD
              I already tried different firmwares, but since is occured the first time, nothing changed while I flashed the different firmwares.
              But it would be nice, if you could test if the behaviour is the same on your system.
              • InpureD
                Hmm,
                do you or someone else here got any further informations? Would be nice, if someone can test, whether he got the same, or its a failure by my controller...
                  paradadf Staff last edited by paradadf
                  Afaik the connect button refreshes the bluetooth conection and isn't a 'button' itself. Do you get any response by jtest?
                  https://github.com/recalbox/recalbox-os/wiki/Test-your-joystick-with-jstest-(EN)
                  Why don't you just use L3 instead and spare you the trouble?
                  • InpureD
                    Hmm, didn't use test till now... Will try it while vacation at the end of the next week and tell you what test is responding.
                    Yeah, maybe ur right and I should just use another button, but I thought maybe I just got an faulty controller and wanted to get this cleared for me 😉
                    101.4k
