    Newcomer questions - Controller, Themes & Settings
    newcomer themes settings
    3397
    • fenomeno0chris
      fenomeno0chris last edited by
      Hi, Im using the latest version of recalbox (4.0.0 - Build 121). It was very easy to set everything up on my rPi3. Thank you very much for this great operating system!
      There are just a few questions I still have.
      • Is there a way to use the DualShock4 wirelessly with the built-in bluetooth feature of the rPi3?
      • Where do I find different themes for recalbox? (In the UI-Settings is an option to change the theme, but there is just one to choose from.)
      • What is the pixel-perfect setting good for?
      • How can I overclock the RaspberryPi? It can not be changed in the settings.
      • Is it possible to change the background music? If yes, where can I find other background songs?
      Keep up the great work you guys are doing!
      • supernature2k
        supernature2k last edited by
        • No, built-in BT will come in Recalbox 4.1
        • On github, you can download other themes. You can also download any theme made for EmulationStation, it should work.
        • This is integer scale, you have explanation in the wiki
        • No overclock settings for Rpi3
        • Yes, just put some ogg 128kbs 44kHz files in music directory. You can find songs...everywhere 🙂
        • fenomeno0chris
          Thank you very much for the fast answer!
          I have found some themes and downloaded them. But where do I have to transfer them? There is no "themes" folder or something like that.
          • supernature2k
            In \\recalbox\share\system\.emulationstation\themes
              paradadf Staff last edited by paradadf
              Small correction (if I'm not mistaken):
              \\recalbox\SHARE_INIT\system\.emulationstation\themes
              and just in case, .emulationstation is a hidden folder.
              • supernature2k
                no need to put it in share_init
                  didn't know that. thanks for the clarification.
