    Pairing Harmony hub remote
    MediaCenter & Dualboot
    pairing harmony hub remote
    • ChimpsInTies
      ChimpsInTies last edited by ChimpsInTies
      First of all, I really like Recalbox and want to migrate to it. A little background. I have always had my Harmony remote connected via bluetooth to any pi I use, mainly so I can control kodi. I was recently using RGB-Pi and it worked prefectly.
      When I moved over to Recalbox and started to set everything up I cannot get it working here.
      Something I have noticed is when I enter pairing mode in the controller setup screen it doesn't show the harmony, but if I try and pair a new audio device in the sound setting screen the harmony does show up there. I can initiate pairing from there and it will connect but it won't allow me to control anything (obviously I guess). I suspect there might be some filtering of the devices Recalbox is allowing to be paired as a controller and it's stopping me seeing my Harmony as an option in the list.
      Any advice on this?
      I can connect my 8BitDo SF30Pro bluetooth controller fine so i know it's not a bluetooth issue.
      Pi4b 4GB with RGBerry scart hat
      v9.2.3 Pulstar
      100.9k
