    Controller not working correctly
    correctly
    5943
    • nhchamplin
      nhchamplin last edited by
      I just got recalbox installed on my raspberry pi 3 but I have two third party PS3 controllers that will not configure. I have gone into the recalbox.conf file and edited the PS3 driver to SHANWAN and still is showing no success. Here is the dmesg output so you can see why I did that.
      [ 457.592673] usb 1-1.4: Product: PS3 GamePad
      [ 457.592680] usb 1-1.4: Manufacturer: SHANWAN
      [ 457.603323] input: SHANWAN PS3 GamePad as /devices/platform/soc/3f980000.usb/usb1/1-1/1-1.4/1-1.4:1.0/0003:054C:0268.0005/input/input4
      [ 457.603817] sony 0003:054C:0268.0005: input,hiddev0,hidraw2: USB HID v1.10 Joystick [SHANWAN PS3 GamePad] on usb-3f980000.usb-1.4/input0
      [ 460.046178] sony 0003:054C:0268.0005: can't resubmit intr, 3f980000.usb-1.4/input0, status -2
      [ 514.091071] usb 1-1.4: USB disconnect, device number 7
      When I plug them in on boot they vibrate constantly but allow me to configure them but if they are unplugged and plugged back in they do not stay configured. Any help on this matter would be very appreciated.
        paradadf Staff @nhchamplin last edited by
        @nhchamplin are you trying to use the internal bluetooth? Currently, it isn't working so you'll need a bluetooth dongle for that.
        • Nachtgarm
          Nachtgarm last edited by
          moved to the correct category
          • digitaLumberjack
            Do you try to play with the ps3 controllers in USB ?
            If so try to deactivate the ps3 driver.
            nhchamplin 2 Replies Last reply Reply Quote 0
            • nhchamplin
              I am not trying to use the internal bluetooth knowing that that is still a work in progress. I am trying to just plug them in with a USB. How do I deactivate the ps3 driver?
                paradadf Staff last edited by paradadf
                On recalbox.conf look for the PS3 part and change it to
                controllers.ps3.enabled=0
                But I thought ps3 controllers wouldn't work over USB at all.
                  Substring @paradadf last edited by
                  @paradadf could that be the trick to make them work over USB ? if it disables sixpair, then it's great
                    paradadf Staff @Substring last edited by paradadf
                    @subs maybe, but I have no ps3 controllers so I can't test XD
                    Anyway, it would be very interesting for people that have them considering the difficulties that those controllers currently have!
                      @paradadf if clones were REAL clones programmatically speaking, we wouldn't have such troubles to make them work 😕
                      Reminder for myself : test a wired PS3 pad tonight, despite I only have shanwan and gasia
                      • nhchamplin
                        I also will have to wait till tonight to test this. Is there any way to track the process on the built in bluetooth? Would love this to work.
                        • nhchamplin
                          nhchamplin @digitaLumberjack last edited by
                          @digitaLumberjack I did play while testing the controller and it worked fine besides that it was vibrating the whole time I played.
                          • nhchamplin
                            @digitaLumberjack There is no change in result after deactivating the ps3 driver.... looks like I am stuck getting a bluetooth dongle if I want to use ps3 controllers.
                            • digitaLumberjack
                              This is what we recommend 🙂
