    RecalBox Manager Web error (Pi5)
    recalbox manager web error
    • DreyMIX
      DreyMIX last edited by DreyMIX
      Hi,
      I recently installed the latest version of RecalBox on Raspberry Pi5 with RGB Dual on CRT. I have a problem with the web configuration interface. It worked correctly only the first time, then every time I restart the Raspberry Pi5, the web page does not work correctly and then dies permanently.
      [2024/10/30 12:35:38.533] (INFO ) : Recalbox Micro Webserver 1.0
      [2024/10/30 12:35:38.553] (INFO ) : Parameters:
      [2024/10/30 12:35:38.563] (INFO ) :   Interface    : 0.0.0.0
      [2024/10/30 12:35:38.573] (INFO ) :   Port         : 80
      [2024/10/30 12:35:38.581] (INFO ) :   Threads      : 10
      [2024/10/30 12:35:38.588] (INFO ) :   Root folder  : /recalbox/web/manager-v3
      [2024/10/30 12:35:38.594] (INFO ) :   Default file : /index.html
      [2024/10/30 12:35:38.601] (INFO ) :   Debug logs   : 0
      [2024/10/30 12:35:38.608] (INFO ) : [RestAPIRouter] Router initialized
      [2024/10/30 12:35:38.615] (INFO ) : [WebServer] Server up!
      [2024/10/30 12:38:01.312] (ERROR) : Signal 15 received.
      [2024/10/30 12:38:01.319] (INFO ) : Server interrupted!
      If I try to force restart the web service via SSH:
      /etc/init.d/S93webmanager restart
      At that point it seems to work. However, every time I restart the machine I have the problem again. ! What could have caused it?
      Thanks
      • thekronics
        thekronics last edited by
        Good morning,
        have you found a definitive solution to your problem? Indeed, I have exactly the same problem as you with the latest version of Recalbox.
        DreyMIX 1 Reply Last reply Reply Quote 0
        • DreyMIX
          DreyMIX @thekronics last edited by
          @thekronics I haven't tried it again
          thekronics 1 Reply Last reply Reply Quote 0
          • thekronics
            thekronics @DreyMIX last edited by
            @DreyMIX
            Thanks for the response already.
            I think this is a general bug in recent versions because it's strange my installation is a priori clean.
            Asthonishia 1 Reply Last reply Reply Quote 0
            • Asthonishia
              Asthonishia @thekronics last edited by
              @thekronics Can you give us screenshots from the web manager console in your browser ?
