    Emulator Exit button GPIO
    GamePad/GPIO/USB encoder
    button gpio stop emulator
    16194
    • crispycritter911
      crispycritter911 last edited by Substring
      I was curious as to modify an existing script to work from retropie to RecalBox. I've got a button wired up to a GPIO pin to exit out of all the emulators on RetroPie 3.8 and on 4.0 Beta. However when I try to use the same script in RecalBox I can see the button output on the terminal screen when pressed. I've used this in the event the emulator freezes up and hotkeys don't work, I can still get back to emulation station.
      from time import sleep
      import os
      import RPi.GPIO as GPIO
      GPIO.setmode(GPIO.BCM)
      GPIO.setup(17, GPIO.IN, pull_up_down=GPIO.PUD_DOWN)
      def exitEmulator(channel):
          print('exitEmulator')
          pids = [pid for pid in os.listdir('/proc') if pid.isdigit()]
          for pid in pids:
              try:
                  commandpath = open(os.path.join('/proc', pid, 'cmdline'), 'rb').read()
                  if commandpath[0:24] == '/opt/retropie/emulators/':
                      os.system('kill -QUIT %s' % pid)
                      print('kill -QUIT %s' % pid)
              except IOError:
                  continue
      GPIO.add_event_detect(17, GPIO.RISING, callback=exitEmulator, bouncetime=500)
      while True:
          sleep(10)
      Thanks
      Here
        Hey !
        That script is great 🙂 your should edit your post to better handle syntax coloring 😉
        The path /opt/retropie/emulators doesn't exist on recalbox. All emulators are stored in /usr/bin, and I wouldt recommend you look for that path. The number of emulators is quite limited : retroarch, mupen64plus, moonlight, scummvm ... Tht.s the ones i can think of right now. I think they are listed in recalboxFiles.py in our configgen python package
        • supernature2k
          supernature2k last edited by
          Sleep 10?
          • crispycritter911
            Yeah, I've copied and pasted it from a Reddit thread. Here is where I got it from.
            https://www.reddit.com/r/raspberry_pi/comments/2yw4fn/finally_set_up_retropie_complete_with_a_gpio/
            I really like the look and feel of RecalBox and wanted to use it in my other pi but had a few hiccups a long the way. One of them being this emulator exit button that I cannot get working on RecalBox. I think the other was the SNES GPIO adapter which I have kind of figured out.
              The script is not that hard to adapt :
              • list binaries that one wants to shutdown. So far, there is moonlight, retroarch, fba2x, kodilauncher.sh, mupen64plus, scummvm
              • instead of getting cmdline, get exe (it's a symbolic link)
              • check that exe is among the listed binaries. If so, kill the pid
              One could make that script way more dirty : just throw a kill of all known processes, anyway only one of them is supposed to run at once
              The next recalbox version will add those binaries : dosbox, PPSSPPSDL, reicast.elf, linapple, x64
              What's your knowledge of python ?
              • crispycritter911
                My knowledge of Python is pretty much nil. I haven't had any real coding background whatsoever. I've tinkered and modified some stuff ini files for the original xbox to help automate flashing bios and setting up hard drives the way I like it. But that's really it. I usually take other peoples code and modify it to suit my needs. I would like to go back to college someday to learn about coding. Thanks for the input.
                  very lazy, didn't even try it :
                  import os
                      os.system('killall retroarch')
                  while True:
                      sleep(10)
                  that can work, only for retroarch for now
                  you should start this file from a custom.sh located at /recalbox/share/system (you need to create it). Create it yourself add python yourfile.py inside, chmod u+x custom.sh and reboot
                  • crispycritter911
                    Thanks, I'll try it in a bit.
                    • supernature2k
                      supernature2k last edited by supernature2k
                      I think import time is needed for the sleep function.
                      Also, I would do it the other way for button press: GPIO.PUD_UP and GPIO.FALLING
                      the code:
                      import os
                      import time
                      GPIO.setup(17, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                      GPIO.add_event_detect(17, GPIO.FALLING, callback=exitEmulator, bouncetime=500)
                      while True:
                          sleep(10)
                      • supernature2k
                        Ok Guys, I made some test.
                        I put a cable on Pin5 and pin6 and run the following code:
                        import os
                        import time
                        GPIO.setup(3, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                            print("exitEmulator")
                            os.system("killall retroarch")
                        GPIO.add_event_detect(3, GPIO.FALLING, callback=exitEmulator, bouncetime=500)
                        while True:
                            time.sleep(10)
                        And... it's working 🙂
                        Of course in this current state, it's only working with retroarch emulators
                          haha i'm the man 😄
                          Seriously, most of emulators are listed in the recalboxFiles.py. Would need to improve it because all bins are not listed there. But I really like this idea : kill the running emulator, or even reset the game (there is a topic on it somewhere, will gid this and update my post) -> https://forum.recalbox.com/topic/3435/game-reset/6
                          • supernature2k
                            solution via python with network commands:
                            import os
                            import time
                            import socket
                            import sys
                            # addressing information of target
                            IPADDR = "127.0.0.1"
                            PORTNUM = 55355
                            # enter the data content of the UDP packet
                            PACKETDATA = "RESET"
                            # initialize a socket, think of it as a cable
                            # SOCK_DGRAM specifies that this is UDP
                            try:
                                s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
                            except socket.error:
                                print 'Failed to create socket'
                                sys.exit()
                            #s.connect((IPADDR, PORTNUM))
                            # connect the socket, think of it as connecting the cable to the address location
                            data = bytes(PACKETDATA)
                            	print(IPADDR)
                            	print(PORTNUM)
                            	print(PACKETDATA)
                            	s.sendto(PACKETDATA, (IPADDR, PORTNUM))
                            while True:
                                time.sleep(10)
                            OyyoDams 1 Reply Last reply Reply Quote 1
                              OyyoDams Staff @supernature2k last edited by OyyoDams
                              @supernature2k Hi,
                              I'm replying to this old topic because I'm currently working on a project that needs such a feature. I tried your last script, I just removed GPIO code at for now to test, so here is my code:
                              import os
                              import time
                              import socket
                              import sys
                              PORTNUM = 55355
                              try:
                                  sys.exit()
                              print(IPADDR)
                              print(PORTNUM)
                              print(PACKETDATA)
                              So to try it, I start a retroarch game then I launch the script:
                              # python rpi-exit-emulator.py
                              exitEmulator
                              127.0.0.1
                              55355
                              RESET
                              But in fact it does nothing, I'm still in the game (with no reset). Any idea ? 🙂
                                Substring @OyyoDams last edited by
                                @oyyodams it's RESET, not exit 😉
                                  OyyoDams Staff @Substring last edited by
                                  @substring yes that's it's supposed to do... but no reset by the way...
                                    @oyyodams check on command line if you can connect to the port 😉 some netcat commands should do it
                                      @substring Well I found a great doc on the wiki. But...
                                      • I can't use netcast: nc is not include in this buildroot build (and I can't rebuild by now)
                                      • It seems retroarch doesn't respond to any command. I tried to edit retroarch.cfg to add network_cmd_enable = "true", nothing better (even after reboot)
                                      I will not let go;)
                                        @oyyodams hold the door !!!
                                          @substring Hodor
                                          Don't worry I keep up the good work, things begin to be better, news soon 😉
                                            OyyoDams Staff last edited by
                                            Ok solution:
                                            network_cmd_enable = "true" has to be added in /recalbox/share/system/configs/retroarch/retroarchcustom.cfg
                                            supernature2k 1 Reply Last reply Reply Quote 0
