    Change RecalBox Resolution on x64 (RecalBox 9.2.1+)
    recalbox x64 9.2.1
    • PlugMeister
      PlugMeister last edited by PlugMeister
      This guide details how to change the display resolution of RecalBox installed on x64 hardware. The instructions are tested for RecalBox version 9.2.1 (Pulsar X64/PC).
      Requirements:
      A separate computer with:
      • Network connection
      • An SSH client installed (e.g., PuTTY)
      RecalBox device with SSH enabled (refer to RecalBox documentation for enabling SSH if needed).
      Basic Knowledge:
      This guide assumes familiarity with basic Linux concepts and using SSH.
      Tools:
      mount: Used to modify file system permissions. More...
      nano: A simple text editor for editing configuration files. More...
      xrandr: Manages display configuration and settings. More...
      reboot: Restarts the RecalBox system. More...
      Steps:
      1. Boot Up:
      • Start your RecalBox device and the separate computer with the SSH client.
      • Ensure both devices are on the same local network.
      2. SSH Connection:
      • Open the SSH client on your separate computer.
      • Locate your RecalBox IP address in the RecalBox menu (Settings -> IP Address).
      • Enter the IP address in the SSH client and connect.
      • Accept any security warnings and log in using your RecalBox credentials (default: username - root, password - recalboxroot).
      3. Stop EmulationStation:
      • In the SSH terminal window, type the following command and press Enter: /etc/init.d/S31emulationstation stop
        Note: This stops the emulation station process.
      4. Enable Write Access:
      • Type the following command and press Enter: mount -o remount, rw /
        Note: This makes the file system writable for editing configuration files.
      5. Edit System Configuration:
      • Type the following command and press Enter: nano /etc/X11/xinit/xinitrc
        Note: This opens the system configuration file in the nano text editor.
      • Locate the line # xrandr --output output_name --off
        (around line 21).
      • Below this line, add a new line with the following format: xrandr {xrandr_parameters}
        Replace {xrandr_parameters} with the actual resolution and display settings you desire. Refer to online resources or Xrandr documentation for available parameters.
      • Save the changes by pressing Ctrl+O and then exit nano with Ctrl+X.
      6. Disable Automatic Configuration:
      • In the same file /etc/X11/xinit/xinitrc, locate the line # /usr/bin/externalscreen.sh (around line 25).
      • Add a # symbol at the beginning of the line to comment it out. This disables RecalBox's automatic display configuration.
      7. Reboot RecalBox:
      • Type the following command and press Enter to restart your RecalBox: reboot
      • After the reboot, your RecalBox should start with the newly configured resolution.
      Additional Tips:
      • Refer to the official RecalBox documentation (https://wiki.recalbox.com/) for advanced display configuration options.
      • In case of any issues, consult online forums or communities for troubleshooting steps specific to your situation.
