    Syncronism Lost when system.power.switch=PIN56PUSH enable
    syncronism lost enable
    • STaRNiGHT
      STaRNiGHT last edited by
      Hello Folks
      I have a problem with my recalbox ... I have Recalbox 9.0.2 in a Raspberry Pi4 and VGA666 conected to my old arcade CRT.. All work fine.. but when enable system.power.switch=PIN56PUSH ... the CRT syncronims fails ...
      Can anyone help me? If I can't use the GPOI pins, do you know another way to configure a key to safely shut down the rapsberry, I use IPAC2.
      Thanks in advance
      • STaRNiGHT
        Autoresponse
        I have found the problem . VGA666 interface use GPIO 2 & 3 for synchronism
        GPIO 02: level=0 fsel=6 alt=2 func=LCD_VSYNC
        GPIO 03: level=0 fsel=6 alt=2 func=LCD_HSYNC
        For the power button function and VGA666 to coexist you have to change the pin, I changed it to 16 and it works without problem.
        recalbox/scripts/rpi-pin56-power.py
        GPIO.setup(16, GPIO.IN, pull_up_down=GPIO.PUD_UP)
        def shutdown():
          os.system("shutdown -h now")
        try:
          if mode == "onoff" :
            GPIO.wait_for_edge(16, GPIO.RISING)
        in case it is of any help to anyone
        chriz74 1 Reply Last reply Reply Quote 0
        • chriz74
          chriz74 @STaRNiGHT last edited by
          @STaRNiGHT my electrohome g07 goes out of sync in system menus using Pi2jamma which has the vga666 circuit too. However afaik I didn’t enable anything like that.
