    Soundbar fail on Recalbox 9.2
    soundbar fail recalbox 9.2
    2010
    • juas
      juas last edited by
      Hello everyone.
      After updating my Recalbox 9.1 to version 9.2 on a Raspberry Pi 3, my sound bar connected to the TV's HDMI-CEC connection has stopped working and the sound comes out through the TV's speakers. If I use version 9.1 again it works without problems. How can I solve this error?
      Thanks!
      Scavy davidb2111 b5turbo 3 Replies Last reply Reply Quote 0
        Scavy Global moderator @juas last edited by
        Hello @juas
        Did you try to connect your BT soundbar using the recalbox BT connection, or to change the sound output in the menu (if its connected) ?
        juas 1 Reply Last reply Reply Quote 0
        • juas
          juas @Scavy last edited by
          @Scavy Hi!
          The sound bar does not have Bluetooth: only HDMI, mini jack and optical. For the optical output I have chosen the only option available for HDMI audio. As I said before, version 9.1 works well but not 9.2.
          Thanks!
          davidb2111 1 Reply Last reply Reply Quote 0
          • davidb2111
            davidb2111 Staff @juas last edited by
            @juas said in Soundbar fail on Recalbox 9.2:
            @Scavy Hi!
            Thanks!
            Hi @juas
            Seems related to CEC and a regression in the kernel and/ord userland libs.
            Will try to find a solution.
            Sorry for the inconvenience.
            David
            • davidb2111
              @juas
              BTW, it's HDMI-ARC. Did you try to change audio output device in sound settings ?
              Just to be sure.
              David
              • juas
                juas @davidb2111 last edited by
                @davidb2111 said in Soundbar fail on Recalbox 9.2:
                @juas
                Just to be sure.
                David
                Hi! I tried it but it still doesn't work. I hope you find the solution.
                Thanks and greetings!
                gona 1 Reply Last reply Reply Quote 0
                • gona
                  gona @juas last edited by
                  @juas same problem here.
                  The strangest things is that when I turn on the Raspberry pi3 with recalbox, all sound coming from the soundbar is not working. Even not switching to the HDMI input of the Raspberry.
                  For example, watching TV channels, I just turn on the Pi, and seconds later the sound mutes automaticaly
                  • b5turbo
                    b5turbo @juas last edited by
                    @juas I have recently changed over from RetroPie to Recalbox and I'm experiencing the same issue with Recalbox 9.2.2-pulsar. I'm using the same Raspberry Pi 3b+ connected via HDMI cable to my TV. The sound bar is also connected via HDMI cable.
                    I tried adding the following line to the /boot/recalbox-user-config.txt file but this didn't help:
                    hdmi_ignore_cec=1
                    • Referenced by  hanjo hanjo
