    how to find recalbox.conf
    find recalbox.conf
    • doblerico
      doblerico last edited by
      hi, i´m mac user.
      I want edit video mode with this tutorial but in my memory card can not find recalbox.conf, where is it ?
      https://github.com/recalbox/recalbox-os/wiki/Video-configuration-detailled-(EN)
      My memory card:
      root/
      bcm2709-rpi-2-b.dtb
      bootcode.bin
      cmdline.txt
      config.txt
      mixup.dat
      os_config.json
      overlays
      recalbox-boot.conf
      start.elf
      zimage
      if i try to edit recalbox-boot.conf i only see:
      internal=/dev/mmcblk0p8
      sharedevice=INTERNAL
      thanks!!
        Hello'
        do you read this page : https://github.com/recalbox/recalbox-os/wiki/recalbox.conf-(EN) ?
        doblerico 1 Reply Last reply Reply Quote 0
        • doblerico
          doblerico @acris last edited by
          @acris said in how to find recalbox.conf:
          yes, where is /recalbox/share/system/recalbox.conf?
          please view my file list in memory card
          • Nachtgarm
            Nachtgarm @doblerico last edited by Nachtgarm
            @doblerico You have to access it via your Network Places. It's a shared folder, not a visible partition you can access on your Mac if you put the SD card in a reader. Leave it in your Pi, boot it up, connect to your network and then check on your Mac in network places (or whatever it is called on a Mac) and find your PI as a shared folder (SMB Share). Inside this shared folder you will find all you need.
              You can't reach the recalbox partitions on mac unless you buy a software. You should plug your pi on your network and get access to it via network
