    Solved custom overlay for megadrive, sega32x, mastersystem
    overlay megadrive sega32x mastersystem
    4876
    • howlerbr
      howlerbr last edited by
      I'm trying to config one overlay for each of those systems. But it sets the last one for all others.
      If recakbox.conf I've added the lines:
      sega32x.configfile=/recalbox/share/system/.config/retroarch/config/picodrive_libretro-2.cfg
      megadrive.configfile=/recalbox/share/system/.config/retroarch/config/picodrive_libretro-6.cfg
      mastersystem.configfile=/recalbox/share/system/.config/retroarch/config/picodrive_libretro-1.cfg
      each of these configuration files is correctly configured to use the right overlay.
      I have noticed that a file picodrive_libretro.so.cfg was created and it seems to be using this one. This file has the last overlay I set.
      What I'm doing wrong?
      tks,
        Hello
        in recalbox overlay is not possible, we must modified configgen and others things to use overlays with differents systems.
        Recalbox team work actually for this integration in recalbox 4.1.0
        you will be patient.
        • howlerbr
          but this is not a retroarch setting?
            Nop it 's more complicated.
              @acris he is using custom retroarch config files, so configgen is greatly bypassed
              @howlerbr how can you be sure your config files work ? You should make a pastebin of each of them if you want us to check
              • howlerbr
                recalbox.conf: http://pastebin.com/uDt9zraB
                See in my recalboxconf example for megadrive.The file it points has the following content (picodrive_libretro-6.cfg) http://pastebin.com/sqPBV6kJ
                But for some reason it uses the conf picodrive_libretro.so.cfg: http://pastebin.com/WbUYcZm9
                tks for the support
                  try to modifiy this line :
                  overlay_directory = "~/.config/retroarch/overlay"
                  config_save_on_exit = "true"
                  to
                  overlay_directory = "~/.config/retroarch/overlay/sega32X"
                  config_save_on_exit = "false"
                    @howlerbr you should link one of your overlay files, and consider manuallt editing your custom cfg files for a better readability. But that's not mandatory. Start following Acris' advice and tell ushow it goes
                    • howlerbr
                      @acris you made may day! tks it worked like a charm!! tks for the support
