    Mount FsTab
    fstab
    1406
    • Inner200k
      Inner200k last edited by
      TLDR; how do you make fstab mount at start up before Recalbox starts it's interface, so that it has a chance of finding the files on my network?.
      Firstly I'm new to RPIs I've just gotten my first one which was a PI5, I'm not however new to Linux hence why when ( https://wiki.recalbox.com/en/tutorials/network/share/roms-on-a-network-share-samba-nas ) this advise completely and totally FAILED! -- I resorted to the the knowledge I knew;
      I put this into fstab;
      //192.168.1.200/RAID/Roms /recalbox/share/roms cifs username=<blank>,password=<blank>
      rebooted -- to a thunderous nothing, after relogging back in and discovering it wasn't mounted, punched it with a mount -a and did a file update in recalbox and all was right with the world.
      however I'm not that much of a fan of doing this every time I want to run recalbox, is there somewhere I can make this mount automatically.
      I did find some solution:
      (DO NOT FOLLOW)
      Yep, I knew that, I didn't want to put there my real username and password. The link you gave did work. Three differences from what I was doing: 1. The mount line on /etc/fstab uses "user", not "username" 2. I had to add the 'mount -a' option to nano /etc/init.d/S31emulationstation 3. I had to do a 'mv /etc/init.d/S31emulationstation /etc/init.d/S92emulationstation' in order to set that file as the one to boot from and mount everything. Solved! Nice πŸ˜‰ Thanks!
      (DO NOT FOLLOW)
      Which completely borked to the system perhaps because it's old advice I'd imagine.
      Any help would be appreciated.
      • zetof
        zetof last edited by
        https://wiki.recalbox.com/fr/tutorials/network/share/roms-on-a-network-share-samba-nas
        https://www.youtube.com/watch?v=ujVeg31Jpgk
        in french...
        Inner200k 1 Reply Last reply Reply Quote 0
        • Pitch64
          Pitch64 Staff last edited by
          All wiki pages in French exist in English πŸ™‚
          Next release? Soonβ„’
          • Inner200k
            Inner200k @zetof last edited by Inner200k
            @zetof first link I've already stated failed, nice Youtube link but I don't speak French. I'm guessing you didn't get past the paragraph TLDR. πŸ™‚
            @Pitch64 indeed, as stated wiki link is of no earthly use, when I followed the tutorial it more or less ignored that I'd even touched the /boot/recalbox-boot.conf it's more or less two steps.
            Step 1.
            Change the sharedevice=NETWORK
            Step 2. (in my case)
            attempt 1: sharenetwork_smb1=ROMS@192.168.1.200:/RAID/Roms:username=<redacted>,<redacted>=recalbox,vers=1.0
            attempt 2: sharenetwork_smb1=ROMS@192.168.1.200:/RAID/Roms:username=<redacted>,<redacted>=recalbox,vers=2.0
            attempt 3: sharenetwork_smb1=ROMS@192.168.1.200:/RAID/Roms:username=<redacted>,<redacted>=recalbox,vers=3.0
            attempt 4: sharenetwork_smb1=ROMS@192.168.1.200:/RAID/Roms:username=<redacted>,<redacted>=recalbox
            (this will just default to 2.0)
            Either way these attempts 1 to 4 failed, I have no clue as to why they failed, considering I fixed the issue another way with near to the exact same config in fstab eg.
            //192.168.1.200/RAID/Roms /recalbox/share/roms cifs username=<redacted>,password=<redacted>
            It however does not automount at boot, which is the issue I'm trying to resolve, I'm pinking I need to edit something in /etc/init.d/ but I'm unsure as to what as the last advice I followed broke the boot sequence.
            • Inner200k
              Inner200k last edited by Inner200k
              -- HACKED --
              since none of the above worked, adding a custom.sh script didn't launch more over the S99custom didn't even load either! I moved to more drastic measures, luckily there was just enough information to access a log file of the boot process that somewhat showed me the way.
              Step 1: mount -o remount,rw /
              Step 2: nano /etc/init.d/S14migrate ( didn't much care which script it was, I'm using a battering ram here not a feather duster, as long as it launched at boot and was before the launch of emulationstation / recalbox I had my victim )
              Step 3:
              # Run this script on startup only
              if [[ $1 != "start" ]]; then
                exit 0
              fi
              # hack mount
              mount -a
              Inserted mount-a below the if statement.
              Step 4: patted myself on the back for being cleaver, and now consider the wiki useless information.
              • Inner200k
                -- actually I only thought it did ignore above.
                Switched to Batocera (ironically the same [[EXACT TO THE LETTER!]] configuration settings I was using found the recalbox wiki for setting up smb over a wired network that didn't work, worked [[EXACT TO THE LETTER!]] on Batocera.
                Copyright Β© 2021 recalbox.com
