    Arduino Leonardo Controller Button Issue on Recalbox with Raspberry Pi 4B
    GamePad/GPIO/USB encoder
    arduino leonardo button issue recalbox
    • HarukiRobotics
      HarukiRobotics last edited by
      Hello Recalbox Community!
      I'm in need of some assistance with a custom Arduino Leonardo game controller I've been working on. I've utilized the ArduinoGamepad library by gamelaster (found here: ArduinoGamepad Examples) to set up my controller. It's functioning perfectly when tested on the Windows gamepad settings—every button press and joystick movement is detected without any hiccups.
      However, I've hit a snag with Recalbox on my Raspberry Pi 4B. While the system does recognize the controller as a Leonardo and allows me to use the joystick to navigate the Recalbox menu**, none of the buttons are being detected within the controller configuration menu.**
      Has anyone experienced a similar issue, or can offer any insights into why this might be happening? Your help would be immensely appreciated to get my custom controller fully operational with Recalbox.
      Thank you in advance!
      • Here is my arduino code:**
      Select: button8
      Start: button9
      Hotkey: button9
      L: button4 (Joystick L button)
      R: button5 (Joystick R button)
      X: button0
      Y: button3
      A: button1
      B: button2
      D-U: axis 1-
      D-D: axis 1+
      D-L: axis 0-
      D-R: axis 0+
      #include <Gamepad.h>
      //left joystick
      int leftXcenter = 500;
      int leftYcenter = 500;
      double multiplierLX = 0.254;
      double multiplierLY = 0.254;
      //right joystick
      int rightXcenter = 500;
      int rightYcenter = 500;
      double multiplierRX = 0.254;
      double multiplierRY = 0.254;
      Gamepad gp;
      void setup() {
        //Left joystick
        pinMode(A0, INPUT);
        pinMode(A1, INPUT);
        //Right joystick
        pinMode(A2, INPUT);
        pinMode(A3, INPUT);
        //Start, Select buttons
        pinMode(2, INPUT_PULLUP);
        pinMode(3,  INPUT_PULLUP);
        //ABXY
        pinMode(4,  INPUT_PULLUP);
        pinMode(5,  INPUT_PULLUP);
        pinMode(6, INPUT_PULLUP);
        pinMode(7,  INPUT_PULLUP);
        //LR
        pinMode(8, INPUT_PULLUP); //Joystick L button
        pinMode(9,  INPUT_PULLUP);//Joystick R button
        calibrate();
      void loop() {
        int lx, ly, rx, ry;
        //left joystick
        lx = analogRead(A0);
        ly = analogRead(A1);
        lx = floor((lx - leftXcenter) * multiplierLX);
        ly = floor((ly - leftYcenter) * multiplierLY);
        if(lx > 127) lx = 127;
        if(ly > 127) ly = 127;
        gp.setLeftXaxis(lx);
        gp.setLeftYaxis(ly);
        //right joystick
        rx = analogRead(A2);
        ry = analogRead(A3);
        rx = floor((rx - rightXcenter) * multiplierRX);
        ry = floor((ry - rightYcenter) * multiplierRY);
        if(rx > 127) rx = 127;
        if(ry > 127) ry = 127;
        gp.setRightXaxis(rx);
        gp.setRightYaxis(ry);
        int select, start, a, b, x, y, l, r;
        select = digitalRead(2);
        start = digitalRead(3);
        a = digitalRead(4);
        b = digitalRead(5);
        x = digitalRead(6);
        y = digitalRead(7);
        l = digitalRead(8);
        r = digitalRead(9);
        if(select == LOW)
      	  gp.setButtonState(8, true);
        else
      	  gp.setButtonState(8, false);
        if(start == LOW)
      	  gp.setButtonState(9, true);
        else
      	  gp.setButtonState(9, false);
        if(a == LOW)
      	  gp.setButtonState(1, true);
        else
      	  gp.setButtonState(1, false);
        if(b == LOW)
      	  gp.setButtonState(2, true);
        else
      	  gp.setButtonState(2, false);
        if(x == LOW)
      	  gp.setButtonState(0, true);
        else
      	  gp.setButtonState(0, false);
        if(y == LOW)
      	  gp.setButtonState(3, true);
        else
      	  gp.setButtonState(3, false);
        //L R button
        if(l == LOW)
      	  gp.setButtonState(4, false);
        else
      	  gp.setButtonState(4, true);
        if(r == LOW)
      	  gp.setButtonState(5, false);
        else
      	  gp.setButtonState(5, true);
        delay(20);
      void calibrate()
        int lx, ly, rx, ry;
        int i = 0;
        while(i < 8)
          bool validLX = lx > (leftXcenter - 100) && lx < (leftXcenter + 100);
          bool validLY = ly > (leftYcenter - 100) && ly < (leftYcenter + 100);
          bool validRX = rx > (rightXcenter - 100) && rx < (rightXcenter + 100);
          bool validRY = ry > (rightYcenter - 100) && ry < (rightYcenter + 100);
          if(validLX && validLY && validRX && validRY)
            i++;
            //nothing to do here!
          else i = 0;
          delay(20);
        leftXcenter = lx;
        leftYcenter = ly;
        multiplierLX = (double)127 / (double)lx;
        multiplierLY = (double)127 / (double)ly;
        rightXcenter = rx;
        rightYcenter = ry;
        multiplierRX = (double)127 / (double)rx;
        multiplierRY = (double)127 / (double)ry;
      bolded text
      100.7k
