    Does Recalbox with Pi2Scart default to 4:3?
    does recalbox pi2scart default
    • slikvik
      slikvik last edited by
      Just a quick question but how does Recalbox and a Pi2Scart know that you're using a 4:3 CRT and not a 16:9?
      • petergray
        petergray last edited by
        While Recalbox with Pi2Scart doesn't automatically detect your TV type, it does default to a safe mode compatible with both 4:3 and 16:9 displays. You'll likely need manual adjustments for optimal output on a specific CRT, but the initial settings prioritize preventing image stretching or cropping on either aspect ratio.
        This means you'll see black bars on a widescreen TV, but your classic games will appear correctly on a 4:3 CRT without further configuration.
        andriodhubp 1 Reply Last reply Reply Quote 0
        • andriodhubp
          andriodhubp Banned @petergray last edited by
          This post is deleted!
