    Nespi4 Case with Recalbox 9.1 Pulstar
    nespi4 case recalbox 9.1 pulstar
    • w4nn4b3h3ro
      w4nn4b3h3ro last edited by
      Hi everyone,
      I upgraded from Version 8.1 to 9.1 on my Pi4 with the retroflag Nespi4 Case. WIth Version 8.1 I had to do the installation according to this tutorial to get the safe shut down working: https://wiki.recalbox.com/en/tutorials/others/nespi4case-installation which worked without any problems. With Version 9.1 I noticed some changes:
      • without USB SSD adapter ES is booting, but in ES I only have the option "RESTART" and not to shut down
      • But the shut-down script is working. By pressing the power button, a small message with "Bye Bye" appers and the Pi is shutting down and powering off.
      So my question: Is this a bug or a feature? 😉
      I don't really need the shut-down Option, when the button and the script is working.
      I found some topics here which described the same beahvior, but I found no answer.
      Kind regards,
      Joachim
      • Magaki
        Magaki last edited by
        Hello,
        It's a feature, like you did before when you want to power off your NES 🙂
        • w4nn4b3h3ro
          Hi,
          Thanks for the answer. I think my qestion might be a bit misleading. 😄
          Is it normal that I now only have the option to Restart Recalbox in the Options Menue?
          Or is this your answer to my first question?
          • Magaki
            Today, it's normal 🙂
