    Multiple wifi doesnt work unless all networks are up????
    wifi rpi4 cm4 gpi case2
    • henryjfry
      henryjfry last edited by
      The problem which was reported in 2017 here:
      https://gitlab.com/recalbox/recalbox-support/-/issues/1329
      Still appears to be an issue.
      If you setup more than 1 wifi in the http://recalbox/recalbox-conf
      And any of the additional wifi networks cannot be accessed, it wont auto connect to any WIFI it detects as being active
      If you prod it with a WPS connection it will connect just fine.
      So i've tested this by enabling 3 WIFI in recalbox.conf
      WIFI 1 = Home Wifi
      WIFI 2 = Phone hotspot
      WIFI 3 = Home Wifi
      With home Wifi disabled the hotspot doesnt connect.
      With the hotspot disabled, the home wifi wont connect.
      So its not a preference order type thing, it seems to hit an empty network and stop trying to connect to anything.
      The only way the home wifi connects is when the phone hotspot is also switched on.
      It does appear to auto switch if a network is disabled though.
      But the actual wifi connection when you specify multiple networks appears to be broken.
      So I think this is some issue with whatever is interacting with the conf file
      I'd just install wpa supplicant and be done, but of cource recalbox wont allow that.
      So is there a fix for actually being able to use more than 1 wifi network which may or may not be currently active?
      This is on the latest version of Recalbox on the RPI Compute Module 4, GPI Case 2
      davidb2111 2 Replies Last reply Reply Quote 0
      • davidb2111
        davidb2111 Staff @henryjfry last edited by
        Hi @henryjfry,
        It's the first time someone reports this error. Let me check this issue.
        David
        • davidb2111
          davidb2111 Staff @henryjfry last edited by davidb2111
          @henryjfry
          Bug spotted. It will be fixed in next release.
          David
          PS: I also added the possibility to set a priority on the wifi network.
          Just set wifi2.priority = 20 to prioritize second wifi (20 is totally arbitrary here, make sure to put higher values to prioritized wifi)
