    VGA666 + Argon One combo doesn't work; black screen
    vga666 argon combo doesnt work
    • nm414
      nm414 last edited by
      Hey, my VGA666 output won't work with the Argon One case, I did type the extra line in the CRT config file, and I can hear the menu music, but the screen is black. At least the TV picked up the sync, so that's something.
      I'm using a Raspberry Pi 4 with four gigs of RAM, if that's helpful.
      abispac 1 Reply Last reply Reply Quote 0
      • abispac
        abispac @nm414 last edited by
        @nm414 I was going to post something similar, but mine dont even boot. I have burned the pi4 image in windows and ubuntu, i it dosnt even boot, i dont have an hdmi cable so im not able to se what the problem is. It dont even creates the share partition.
        only change i made is to the crt-options.cfg to adapter.type = vga666. Do you think you can share your config and crt config file to see if i can make mine boot please.
        nm414 1 Reply Last reply Reply Quote 0
        • nm414
          nm414 @abispac last edited by
          @abispac Oh, I actually just flashed the image to the SD, added the vga666 line, turned the rpi on and waited for the file system to expand. After a bit, it just booted up, I didn't really do anything special.
          • abispac
            @nm414 on mine i had to uncoment the hdmi thing on the pi4 line, cant remember exactly wich one, all working just fine now.
            • nm414
              @abispac Can't find anything uncommentable, do you mean you had to comment something?
