    Amiga Save States not working
    Emulator Arcade/PC/Console
    save state amiga
    • bubbler
      bubbler last edited by
      I have the exact same problem as described here: https://forum.recalbox.com/topic/24904/recalbox-7-2-2-pi-4-amiberry-savestates-not-working
      Trying to save just gets me out of the menu back to the game, and the savegame is not existing.
      I´m on Recalbox 8
        Scavy Global moderator @bubbler last edited by
        @bubbler hi, which core do you use ?
        bubbler 1 Reply Last reply Reply Quote 0
        • bubbler
          bubbler @Scavy last edited by
          @Scavy Hi, what do you mean by core? Amiberry? Saving works with the other Amiga emulators, I just tested that. But Amiberry is the default and it also worked with an older version with my Raspi 3.
            @bubbler Oki so the problem is only with Amiberry.
            • bubbler
              @Scavy yes, Amiberry has this different type of saving, where you cannot simply save with the button combination, but you have to go into the Amiberry menu and save there.
              I also think (and I´ve read that in another thread) that the Amiberry WHDLOAD files are not saved. If I´m right they should only be created once, not on every game start.
              Here are two guys who had the same issue btw, the thread is in german: https://forum.recalbox.com/topic/24264/recalbox-7-2-1-amiga-save-state/4
              Could this be connected to me using an additional SD Card just for the games?
              101.4k
