    My recalbox does not restart and does not enter any games, how to solve this?
    recalbox does restart enter solve
    2214
    • MarcelodeAzevedo
      MarcelodeAzevedo last edited by
      the following message appears. We found no emulators! Check that the directories are correct in the systems configuration file.....
      I believe there was some conflict.
      • Referenced by  Scavy Scavy
        Scavy Global moderator @MarcelodeAzevedo last edited by
        @MarcelodeAzevedo hi, what is your version ? pi4, PC ?
        can you give us more details ?
        https://forum.recalbox.com/topic/3647/before-posting
        MarcelodeAzevedo 1 Reply Last reply Reply Quote 0
        • MarcelodeAzevedo
          MarcelodeAzevedo @Scavy last edited by
          @Scavy pi3
            @MarcelodeAzevedo what is your sd card ? brand & class ?
            • MarcelodeAzevedo
              @Scavy sdcard
                @MarcelodeAzevedo a sandisk card ? class 10 ?
                • MarcelodeAzevedo
                  @Scavy
                  I opened it here and it says
                  raspberry 3 model b v2 2015 - scandisk - class 10
                    @MarcelodeAzevedo ??
                    You can't get out the sd card only ?
                    what do you mean by "i opened it". What did you open ?
                    Or did you buy a recalbox stuff online ?
                    • MarcelodeAzevedo
                      @Scavy said in My recalbox does not restart and does not enter any games, how to solve this?:
                      I bought an arcade that I've had for about 2 or 3 years, but as I said, my son put another jostick in the usb port and it generated a conflict that stopped restarting, when I need to change the game I have to turn it off and on again. and now I wanted to update the equipment, but the IT technician went to put a mouse in the door and ended up disconfiguring the game emulators. I don't know what to do because if I could restore it when I bought it, I believe it would solve the problems, the games are there, but I don't know where to move, and solve it. If you have any option that I can see where you configure the emulator games already solve something
                        @MarcelodeAzevedo i suggest you contact your technician, as far as we don't know how is configured your arcade cabinet, ans the modifications they brought.
                        It's still annoying i can understand it, but our help will be useless as far as we do not know anything about your arcade set-up.
                        • gulshan212
                          gulshan212 last edited by
                          Hello this is Gulshan Negi
                          Well, you need to reinstall the program and then check again. Hope it will work.
                          Thanks
