    Adding a Bluetooth Keyboard (Aerb mini bluetooth keyboard)
    jeu mame mario
    11055
    • kryptto
      kryptto last edited by
      So I have followed the instructions for adding Bluetooth devices: https://github.com/digitalLumberjack/recalbox-os/wiki/Connect-bluetooth-controller-with-hcitool-and-hidd-manually-(EN) I am using the Orinco BT adapter recommended from the tested for compatibility page. It connects to my PS3 wireless controller just fine. I manually add the keyboard per the link above. The keyboard works, but if I turn off the keyboard or reboot the RaspberryPI2 I lose the settings and have to add it from scratch. Is there a way to permanently add that keyboard into a Config file so it can always be available? Kryptto
      PI 3B+ Recalbox 4.1
      • digitaLumberjack
        Hi, use this mini how to : https://github.com/digitalLumberjack/recalbox-os/wiki/Add-your-own-startup-script-(EN)
        • kryptto
          Thanks Retroboy, not being a Linux guru, but isn't your OS locked down? How will using an editor be accomplished if I can't add it to the OS? Do I need to connect using telnet from another Linux machine running Nano?
          PI 3B+ Recalbox 4.1
          • digitaLumberjack
            You can use nano after you connected through ssh with putty : https://github.com/digitalLumberjack/recalbox-os/wiki/Mini-How-To-(EN) check the root access
            • kryptto
              Thanks for clarifying, much appreciated. I love this retro gaming emulator build. I have tried several... They all sucked on many if not all levels. Please keep up the great work!
              PI 3B+ Recalbox 4.1
              • digitaLumberjack
                I will 🙂
                • kryptto
                  For those Windows folks looking for an excellent gui for working on your Recalbox OS, download the following programs: http://winscp.net/eng/index.php http://www.chiark.greenend.org.uk/~sgtatham/putty/download.html Download the x86/x64 version of PuTTY and place in the a folder you create named PuTTY: C:\Program Files (x86)\PuTTY (Windows 64bit OS shown here) Username and Password for the Recalbox OS is : root / recalboxroot
                  PI 3B+ Recalbox 4.1
                    Hi kryptto , if you can make a script to pair your keyboard to start the pi could you share it with us and post your code ? thanks a lot.
                    • kryptto
                      #!/bin/bash
                      hidd --connect CC:BB:CC:AA:BB:CC
                      Ahh, that was it. I had to make the file have the proper permissions to kickoff by the OS. See attached Screenshot.
                      PI 3B+ Recalbox 4.1
                        Hello thank a lot
                        • kryptto
                          Acris
                          I saw you have a forum post in French with the Bluetooth config file. I wish I could understand french better. Something tells me by the looks of your post my primitive attempt is sheer luck. ~kryptto
                          PI 3B+ Recalbox 4.1
                            Hello Yes, I posted a script to connect bluetooth controllers and it does not work with the keyboard and mouse apparently. Your simple line work fine with a another member 😄 I can translate it if you want to try
                            • kryptto
                              Unfortunately my fix works to autostart the keyboard on boot, as soon as my keyboard goes to 'sleep' and I hit any button, no response from the RPI. Anyone have ideas of additional code to add to make my settings more persistent? Kryptto
                              PI 3B+ Recalbox 4.1
                                Hello try this command line :
                                #!/bin/bash
                                hidd --connect CC:BB:CC:AA:BB:CC --server
                                • kryptto
                                  Acris, Thanks for the advice, the addition of the --server command doesn't allow the command to complete. The keyboard never attaches. The pairing light normally will go steady once paired, the --server command never allows that pairing to complete. Kryptto
                                  PI 3B+ Recalbox 4.1
                                  • kalelra
                                    kalelra last edited by
                                    So here is what I did with addition of the startup script   Edit main.conf and rfcomm.conf files underr /etc/bluetooth   Change your mac address in here next to "device" and delete the "#" sign to the left of the comment. # Bluetooth address of the device #       device 11:22:33:44:55:66;     edited main.conf file -add your bluetooth mac address to DeviceID field. # Possible vendor id source values: bluetooth, usb (defaults to usb) DeviceID = bluetooth🔢5678:abcd Another thing was that I hit the sync button on start up as well when rebooting raspberry pi or starting raspberry pi. hope that helps someone else!
                                    • kryptto
                                      Thanks Rico I will try your suggestion!
                                      PI 3B+ Recalbox 4.1
