    Hyperion Support ?
    hyperion
    10
    16
    4915
    • christian-mitnachname
      christian-mitnachname last edited by
      Hello, i found your Image today and i love it. Now i started to config the new Pie2 and all i need to complete it is Hyperion. Is it possible to add/install it ? And if it is possible what tutorial i have to use ? greeting from germany Chris
      • digitaLumberjack
        Hi, Hyperion looks nice, i'll see if i can add it in next releases.
          Hi, that would be great. And i think it looks amazing to play the Games with this "Ambilight" 🙂
          • digitaLumberjack
            Yep 😉
            • raulval82
              raulval82 last edited by
              And please add a turn ON/OFF button in emulation station... I had it in Openelec and it's amazing! http://blog.nadnerb.co.uk/?p=11
              • digitaLumberjack
                Don't hesitate to add this feature by commenting the issue.
                • serioustk
                  serioustk last edited by
                  Hi, did you already manage to include Hyperion? I cannot find any info in the changelog... Kind Regards, Tobi
                    Hi, it is in the todo list, so maybe in a next release. If someone with hardware want try to add hyperion to recalbox, don't hesitate to contact us here or on irc to have more information/help.
                    • deadkenny
                      deadkenny last edited by
                      some news for V4.0? I can help, i've got the hardware but i'm rookie in linux and developpement. It's easy to install with the official wiki on xbian or raspbmc (openelec, osmc or retropie too) https://github.com/tvdzwan/hyperion/wiki/Installation https://www.youtube.com/watch?v=g0do7WG6lfk&feature=youtu.be regards ----- une perspective sur la V4.0? j'ai le matos pour tester, je peux aider mais mes compétences en linux se limitent à l'install... Ca marche pour moi en raspbmc ou xbian, j'ai fait des tests sur retropie mais j'ai du merder sur un truc... https://github.com/tvdzwan/hyperion/wiki/Installation https://www.youtube.com/watch?v=g0do7WG6lfk&feature=youtu.be A+
                      • michael-murphy
                        michael-murphy last edited by
                        Problem I have had with making changes to Recal box is apt Just not able to install packages, which I believe by design but if someone knows of a different package maker let me know. So I have a dual boot, OpenElec/Recalbox image using noobs the last beta before 4.0. In OpenElec I have managed to add the kodi addons which enable boblight. However any attempts at adding the packages for boblight in recalbox have been unsuccssfull.   If someone could walk me through what pkg manager we can use,  or if someone can add the following dependencies, it could be manually configured, I could even share a default config file.  Only other thing is possible some form of UI support for configuring which would likely do something like recalbox does in the frontend, allowing editing of the configuration file over http, and possibly adding settings to the UI menu. Dependencies needed, <span style="color: #3f3f3f; font-family: Monaco, Consolas, 'Andale Mono', 'DejaVu Sans Mono', monospace; font-size: 15px; line-height: normal;">libqtcore4 libqtgui4 libqt4-network libusb-1.0-0 libprotobuf7 ca-certificates </span> Then we need to deconstruct the installation script.   <pre style="color: #000000; line-height: normal;">PATH="/sbin:$PATH" Seems very specific to know the path.
                        <pre># Find out if we are on Raspbmc
                        IS_XBIAN=cat /etc/issue | grep XBian | wc -l
                        IS_RASPBMC=cat /etc/issue | grep Raspbmc | wc -l
                        IS_OPENELEC=cat /etc/issue | grep -m 1 OpenELEC | wc -l
                        Possibly edit this script or manually create a script to adjust for environment variables that are static.
                        </pre>
                        <pre># Find out if its an imx6 device
                        IS_IMX6=cat /proc/cpuinfo | grep i.MX6 | wc -l
                        We need to know if this is Imx6
                        Then just take all actions depending on the environment if I could just figure out how to get the dependencies in, I could probably figure out all the path and startup issues as I have the hardware.
                        </pre>
                          hyperion supoprt is on my todo list. eed someone to try https://github.com/tvdzwan/hyperion/wiki/Installation#deployment, i wonder if, with just a few updates to the downloaded script install_hyperion.sh, it could work
                          • reivaax
                            reivaax last edited by
                            @Michael Murphy Recalbox is a buildroot release. You can't add package without rebuild all the release... But if you now the package needed for hyperion support, you can give your help in the issue : https://github.com/recalbox/recalbox-os/issues/36   thank's for your contribution ;).
                            • michael-murphy
                              Since I have the hardware I am going to try this what subs suggested, I will let you know where I get with it. Runing ./install_hyperion.sh failed. TP request sent, awaiting response... 200 OK Length: 8037430 (7.7M) [application/octet-stream] Saving to: 'STDOUT'   -                     0%[                    ]       0  --.-KB/s    in 0.06s     Cannot write to '-' (Success). ln: /usr/bin/hyperiond: Read-only file system ln: /usr/bin/hyperion-remote: Read-only file system ln: /usr/bin/hyperion-v4l2: Read-only file system ln: /etc/hyperion.config.json: Read-only file system   You can replicate this without Hyperion hardware. If you can create a build, with the following packages, libqtcore4 libqtgui4 libqt4-network libusb-1.0-0 ca-certificates   and RW access to /usr/bin and /etc I could attempt again for testing purposes.
                                @michael-murphy you can't use the script as-is for several reasons : /opt doesn't exist on recalbox, and most of / is read-only. but you can still download yourself the binary and give it a go
                                Alexander Burdin 1 Reply Last reply Reply Quote 0
                                • Alexander Burdin
                                  Alexander Burdin @Substring last edited by
                                  @substring hello. No manuals for start hyperion on recalbox/kodi?
                                    Substring @Alexander Burdin last edited by
                                    @alexander-burdin d**n don't necro such old topics ! Nope, nothing happened yet, no one among the team has what it takes to test anyway.
                                    100.8k
