    RPi 3&4: No HW acceleration for kodi (h264 & h265)
    MediaCenter & Dualboot
    acceleration kodi h264 h265
    3171
    • loki1985
      loki1985 last edited by loki1985
      Hi there,
      longtime happy user of Recalbox here.
      I use the included Kodi media player quite a bit and noticed that apparently since 8.x.x versions there is no more HW acceleration for videos enabled.
      I just updated my RPi 4b+ to 8.1, at least h265 is unwatchable and completely sluggish. h264 seems to work but i fear this is decoded purely in software.
      My RPi 3b+ is still on 8.0.2 and has the same issue. Of course no h265 HW support on the 3b+, but h264 is sluggish and unwatchable.
      Hope this isssue can be fixed, especially since it used to work on older versions of Recalbox (pre-8.x.x that is)
      • ion
        ion last edited by
        I have the same issue.
        • praefectum
          praefectum last edited by
          Same problem for me as well...
          h265 HW acceleration disabled
          • loki1985
            Maybe related to https://github.com/raspberrypi/linux/issues/4112
            There it seems Kernel 5.10 is the problem, downgrading to 5.4 seems to solve the issue.
            No idea what Kernel is actually used for the current 8.1 images tho.
            praefectum 1 Reply Last reply Reply Quote 0
            • praefectum
              praefectum @loki1985 last edited by
              @loki1985 Kernel is now 5.15, I also tried the solution you proposed but to no avail...
              • danielr
                danielr last edited by
                Same for me, the cpu does all the work on kodi since v8 of recalbox. I've reported this a few times on this forum, discord and well as created an issue on gitlab https://gitlab.com/recalbox/recalbox/-/issues/2162 but unfortulately every new release still has the same problem so far.
                Looking forward to this being resolved so I can finally dust out my RPi4 recalbox and enjoy x265 hardware decoding. For now, sticking with my Rpi3B+ on recalbox 7.1.1 as my daily setup.
                Alvin 2 Replies Last reply Reply Quote 0
                • Alvin
                  Alvin Banned @danielr last edited by
                  So why not use LibreElec
                  https://libreelec.tv/downloads/raspberry/
                  with your Pi 4 to watch Movies and the (already working) Recalbox 7.1.1 on your Pi 3B+ to play Games ?
                  1. LibreElec uses the last Version of Kodi (19), RecalBox don't !
                  2. Don't update to RecalBox 8 !
                    Look around on this Board, it seems that this Version give People a lot of Trouble.
                    For this Reason I'm still using RecalBox 6 on m,y Pi 3B+ and it works great without any Problems.
                  danielr 1 Reply Last reply Reply Quote 0
                  • danielr
                    danielr @Alvin last edited by
                    @Alvin Sorry I actually meant version 7.2.2 which is the one that works best for me (and could probably still be downloaded on archive.org).
                    I thought about installing LibreElec standalone but my raspberry is inside a retroflag case and recalbox added some very convenient ways to manage safe shutdown. Also I'm using kodi 95% of the time but it's still nice to be able to play the odd game on the recalbox side when I feel like it.
                    Thanks for the suggestion though, I might give it a try just to see if the official LibreElec has the same troubles with RPi4, might help narrowing down the issue.
                    • Alvin
                      Ok, so if RecalBox 7.2.2 works for you, stay with it
                      @danielr said in [RPi 3&4: No HW acceleration for
                      So I assume that you own a Pi 3b+ in a Retroflag Case with working Recalbox 7.2.2 on in and a Pi 4 to.
                      If that's so, "dust out" the Pi 4, get a SD-Card and install LibreElec on in, and use the Pi3b+ in the Retroflag Case for gaming.
                      Or did I get it wrong ?
                      If the Pi 4 is in the Retroflag Case, than where is the Pi 3B+ you mentioned ?
                      If the Pi 4 is in the Retroflag Case, take it out,
                      buy a simple Case
                      https://www.raspberrypi.com/products/raspberry-pi-4-case/
                      a Powersupply
                      https://www.raspberrypi.com/products/type-c-power-supply/
                      and maybe a HDMI-Cable
                      https://www.raspberrypi.com/products/micro-hdmi-to-standard-hdmi-a-cable/
                      and installe LibreElec.
                      That's way better than waiting for other Things that (maybe) will never happen.
