    RecalBox x64 / PC = No sound over HDMI to TV
    recalbox x64 sound hdmi
    4538
    • dam_j
      dam_j last edited by
      Hello,
      I finally finished a new HTPC (AMD 5600x / Nvidia 3060) and made a fresh RecalBox USB-Stick yesterday with version 8.0.1.
      All seems to work besides HDMI-Audio to TV, i have 6 (!) HDMI / Displayport Audio devices to choose from but nothing works...
      • I tried this on three different TV´s, (LG / Samsung / Sony) nut its always the same
      • I made a Pi 4 with RecalBox 8.0.2 and HDMI-Audio works everywhere
      • My cheap Logitech USB-Speakers also worked perfectly fine with the PC
      What else can i try ??
      Exact PC-Specification:
      • AMD 5600x (not yet OC)
      • Asus B550-I MotherBoard
      • G.Skill 16GB 3600MHz Dual-Channel KIT
      • EVGA RTX 3060 XC Gaming
      • Samsung SSD 980 PRO 1TB
      • Corsair SF Series Platinum SF600
      Thanks in advance !
      Zing Alvin 3 Replies Last reply Reply Quote -1
        Zing Global moderator Translator @dam_j last edited by
        @dam_j See if this helps:
        • https://wiki.recalbox.com/fr/tutorials/audio/fix-emulationstation-sound-issues
        • https://forum.recalbox.com/topic/25592/pas-de-son-dans-les-emulateurs
        dam_j 1 Reply Last reply Reply Quote 0
        • dam_j
          dam_j @Zing last edited by dam_j
          @zing I found / tried the second link before with no luck. Also the first link doesn´t solve my problem.
          Besides the two links are for a different kind of problem since i don´t have any kind of sound not abnormal or only in Recalbox but not in games.
          Thanks anyway !
            @dam_j Try this:
            https://wiki.recalbox.com/en/tutorials/video/display-configuration/external-screen-configuration
            • dam_j
              @zing Also don´t work, i even tried all "DP"´s through and rebooted after every change.
              • Alvin
                Alvin Banned @dam_j last edited by Alvin
                @dam_j
                1. Stupid Question but did you try another HDMI Cabel ?
                  Did your Cable can handle HDMI 2.1 ?
                2. It seems that the EVGA RTX 3060 XC Gaming Grapic Card has 4 Outputs
                  3x Displayport and 1x HDMI.
                  Did you check the Recalbox.conf File ?
                  What did it say under
                ------------ C - Audio ------------
                Set the audio device (auto, hdmi, jack)
                audio.device=auto
                Set system volume (0..100)
                audio.volume=90
                Enable or disable system sounds in ES (0,1)
                audio.bgmusic=1
                If not set I would suggest that you set "audio.device" to "hdmi"
                The default recalbox.conf file for PC
                https://gitlab.com/recalbox/recalbox/blob/master/package/recalbox-system/x86_64/recalbox.conf
                1. Did you try to Reset your Recalbox to Factory Settings and than start it again (with your TV connected and turned on before you start Recalbox ?)
                  https://wiki.recalbox.com/en/basic-usage/features/reset-to-factory-settings
                • dam_j
                  dam_j @Alvin last edited by
                  @alvin
                  Another HDMI = Yes
                  48GB HDMI = Yes
                  Volume is 90%
                  System sounds are on
                  I tried Automatic and HDMI, nothing changed...
                  • dam_j
                    dam_j @dam_j last edited by
                    @dam_j
                    Reset = Yes
                    Complete new install on new USB = Yes
                    • dam_j
                      @dam_j !
                      alt text
                      https://ibb.co/RCtF4f8
                      What me also wonders is that my System is working really hard for just idleling in the menu...
                      • Alvin
                        @dam_j said in RecalBox x64 / PC = No sound over HDMI to TV:
                        There is a Displayport and an HDMI-Port on your Motherboard
                        Your Graphiccard has 3 Displayports and 1 HDMI Port.
                        This makes 4 Displayports & 2 HDMI Ports = 6 Ports where you can get the Audio from.
                        Also the Motherboard has Audio-Connections and a Build-In HD Audio-Controller.
                        1, In the BIOS of your Motherboard, did you check the right Video-Ouput ?
                        See Page 27 on the Manual of your Motherboard -
                        Primary Video Device should be set to "PCIE Video
                        1. Did you disable the Onboard HD Audio Controller
                          See Page 29 - Point 6,5 "Onboard Devices Configuration" on the Manual of your Motherboard ?
                        • dam_j
                          @alvin
                          • The Onboard HD-Audio is disabled
                          • I don´t see any primary video option cause my AMD 5600x doesn´t have integrate graphics, so the DP and HDMI ports on my motherboard have no function
                          • Alvin
                            So what are these Devices called in Recalbox?
                            • dam_j
                              @alvin
                              Can´t tell you that
                              Alvin 1 Reply Last reply Reply Quote -1
                              • Alvin
                                @alvin
                                Can´t tell you that
                                Okayyyy....
                                Do you know what ?
                                If yon can't or won't tell me without any reason I'm out of here.
                                Good Luck with your Problem !
                                • dam_j
                                  @alvin
                                  Sorry that you out of here because i can´t answer you a question about RecalBox...
                                  Zing 1 Reply Last reply Reply Quote -1
                                    @dam_j Please download and install the latest official version that has just been released, and test again:
                                    https://www.recalbox.com/download/
                                    dam_j 2 Replies Last reply Reply Quote 0
                                    • dam_j
                                      @zing
                                      Will do that ! Thanks.
                                      • dam_j
                                        @zing
                                        Ok, with 8.1 the only Audio Output device i have now is "DUMMY OUTPUT" which sadly doesn´t work.
                                          @dam_j I can only imagine that the problem then is a driver incompatibility with your video card, and it's not something a user can solve on their own.
                                          Some options:
                                          • Open an issue in gitlab (check if there is not already a similar issue open), and wait for a response from one of the developers
                                            https://gitlab.com/recalbox/recalbox/-/issues
                                          • Go to our official Discord channel and see if anyone has any other ideas (there's a chance a developer will answer you)
                                            https://discord.com/invite/NbQFbGM
                                          • Invest financially in the project by becoming a Patron Recalbox, and have some special advantages, such as access to an exclusive discord channel:
                                            https://www.patreon.com/recalbox?utm_source=recalbox&utm_medium=website
