    Reset Button Recalbox 8.0.2
    GamePad/GPIO/USB encoder
    reset button recalbox 8.0.2
    • berti2k
      berti2k last edited by berti2k
      Hi there,
      I'm in the process of installing a Pi 3 into an NES case and I can't get the reset button to work. According to the wiki I have entered system.power.switch=PIN56PUSHRESET in the recalbox.conf and connected pins 5 and 6 on the Pi. According to the meter, the pressure switch also works correctly (continuity when pressed).
      What is it about the recalbox.conf-pre-8.0.2-Electron? Is there also a change to be made?
      Do the GPIOs still have to be activated somehow or are other settings required?
      Thanks a lot
        Zing Global moderator Translator @berti2k last edited by
        @berti2k Read the documentation carefully, there is a configuration for the on/off button, and another for the reset button:
        • https://wiki.recalbox.com/en/tutorials/others/add-on-off-button-to-your-recalbox
        berti2k 1 Reply Last reply Reply Quote 0
        • berti2k
          berti2k @Zing last edited by
          @zing
          Thanks for the help, I connected the cable properly and it worked.
          Is there a way that I can adjust the mapping or is that fixed? How does it look like with two-digit GPIOs? For example, if I want to pin 31 (GPIO 6) because I still need 5 and 6?
            @berti2k Sorry, I believe the commands are fixed, not editable. But, I'm not a developer, I can't say that it's impossible, but I can say that it's not something an average user can do.
            I don't know what you want to do with the GPIOs, but, see if there's any documentation for that, I know we have something for controllers, for example:
            https://wiki.recalbox.com/en/tutorials/controllers/gpio
