    repair screenscraper on RecalBox 6.1 Dragonblaze
    repair screenscraper recalbox 6.1 dragonblaze
    • fonzman
      fonzman last edited by
      Title says it all:
      screenscraper.fr seems broken on 6.x/Dragonblaze. I edited /recalbox/share/system/recalbox.conf and removed the ";" from the respecitve lines in the ## Scrapers section. I added my username and password from screenscraper.fr
      The config now looks similar to RecalBox 8.x, but scraping still does not work on 6.1.1
      So my question is, where is the script actually doing the scraping, and how can I update/repair it, to work on RecalBox 6.1.1 as it does on RecalBox 8.x ?
      Can anyone with extended knowledge about the background scripts help me please?
      Thanks.
      Concerning the upcoming "why stick to thew old version? switch to Recalbox 8"-postings: My Recalbox 6.1.1 and Kodi 17 are configered to access roms and movies from my NAS. I assume the NAS only supports Samba V1, or at least I could not connect it to neither Recalbox 7 nor 8. After two frustrating days I simply switched back to my working 6.1.1 setup, and will stay there.
      • Alvin
        Alvin Banned @fonzman last edited by Alvin
        @fonzman
        Sorry, but there's no Support for old Versions of Recalbox here (if you don't believe me just wait, maybe some Mod will tell you the same).
        The Scrapper in Recalbox 6.x is broken and disabled, and nobody will fix it.
        (For example look here:
        https://forum.recalbox.com/topic/18326/scraper-not-working-on-6-0 )
        I've got the same Problem (using Recalbox 6.0 on a Raspberry Pi 3B+) and I'm using ARRM as a Scraper - Works way better than the Recalbox-Scraper.
        • fonzman
          Thanks Alvin for the confirmation.
          My own research tells me that the scraper options are compiled directly into the /usr/bin/emulationstation binary and therefore not editable.
          As I cannot compile the right version for RPi3 and RecalBox 6.x myself, I won't waste more time.
          Also thanks for the recommendation of ARRM, I'll give it a try.
          101.4k
