    News on pi3 overclock in recalbox ?
    news pi3 overclock
    7
    13
    18273
    • slowmo310
      slowmo310 last edited by
      Hi, it's been a while and I see nothing mentioned about overclock settings for the pi3 in recalbox. Does anyone know how to force it ?
      • digitaLumberjack
        Hi, it's useless to overclock the rpi3, but you can use the raspberry pi standard overclock process if you really want to do it : https://www.raspberrypi.org/documentation/configuration/config-txt.md Search for overclock. This file (config.txt) is in the boot partition. You should remount it read-write before editing the file with vi or nano. Feel free to tell us what are the overclock settings you found stable and we see if we add it to recalbox 🙂
        • slowmo310
          Thank you for responding great master. I will give you my results. I use a active cooled case as well as aluminum heatsinks.
          • nosfay
            nosfay last edited by
            @digitalLumberjack , there is this post in french section. Author saids overclock is really a plus for Reicast (Dreamcast) at 1450mhz with a dissipator and he also put his configuration. I personally think a 1350mhz OC could be perfect for PSX with enhanced resolution mode enabled, without, it's a bit laggy with some games when there is too many animations (crash team racing, crash bandicoot 3, for example).
            • digitaLumberjack
              Nice to know, maybe we can create an issue and set inside the different configurations for people to test and report stability. Then we can add them to recalboxOS. Can i let you manage that @nosfay ?
              • nosfay
                I'll do it today 🙂
                • dave-pictonite
                  dave-pictonite last edited by
                  <p style="text-align: left;">Any news on this? How can also you said about using old method. What doni need to do to the config file</p>
                  • dave-pictonite
                    What do I need to do
                      Hello overlock settings for rpi3 will be add in recalbox 4.1 https://github.com/recalbox/recalbox-os/issues/896
                      • dave-pictonite
                        When is 4.1 out if you don't mind me asking
                          an day, when 4.0.0 stable will be realease check milestones https://github.com/recalbox/recalbox-os/milestones
                          • chamilonster
                            chamilonster last edited by
                            recalbox is a master team!!!4
                            • Ratte
                              Ratte last edited by
                              https://youtu.be/uaDdpDwPQkg
                              Recalbox 4.1 (build42)
                              N64 with F-Zero X
                              2nd Demotrack
                              1200 MHz vs 1350 MHz
                              BR
                              Ratte
                              •Raspberry Pi model: Pi ZeroW
                              •Raspberry Pi model: Pi 3B @ 1350/500/500 MHz
                              •Raspberry Pi model: Pi 3B+ @ 1550/500/500 MHz
