    Duckstation PSX
    Emulator Arcade/PC/Console
    duckstation
    • salvo
      salvo last edited by
      Dear all,
      I would nee an help, yesterday evening I was running a PSX rom and to improve the graphics I managed the Hardware by activating Vulcan Hardware, after I activated it the rom has closed itself and by then I cannot run anymor any PSX rom with Duckstation, how can I modify the duckstation hardware without launching any rom with it?
      Thanks in advance
      Regards
        Zing Global moderator Translator @salvo last edited by
        @salvo Look for the configuration files of this emulator, you will be able to edit them manually.
        You can also create a Configuration override file:
        • https://wiki.recalbox.com/en/advanced-usage/configuration-override
        • https://wiki.recalbox.com/en/advanced-usage/configuration-override/retroarch-overrides
        Or you can do a factory reset, it's an option available through the advanced settings menu, you won't lose any personal files, but you will lose all your customizations.
        Maybe this helps:
        https://wiki.recalbox.com/en/emulators/consoles/playstation-1/duckstation
        • Referenced by  Haruko Haruko
