    The main operating system is lost?
    main operating lost
    • Thenouk
      Thenouk last edited by
      If I use the bootable usb and then go out and boot from a Windows hard drive, does anything happen?
      It may seem obvious but I can't find any information on this
      I use Windows, but if I want to use the bootable usb and then go back to my main hard drive, will anything happen?
        Zing Global moderator Translator @Thenouk last edited by
        @thenouk If you are using Windows on a hard drive, and Recalbox on a USB stick, one system will not interfere with the other, as they are not run at the same time, nor on the same storage device.
        Many people use 2 Operating Systems on 1 single computer, such as Windows and Linux, this is very common, it is called dual boot. Usually people install two OS on a single HD, and despite being something relatively safe for those who are used to it, there is a small risk of one system interfering with the other (because they are on the same HD), but this is not your case.
        We do not recommend installing Recalbox on the same hard drive as another operating system, as there is a small risk involved, but you are doing the right thing, and installing Recalbox on a dedicated storage device, so no need to worry.
        Thenouk 1 Reply Last reply Reply Quote 1
        • Thenouk
          Thenouk @Zing last edited by
          @zing thanks!
