    Can't connect to wifi rp4 and Recalbox 8.02
    cant connect wifi rp4 recalbox
    • kiki_tls
      kiki_tls last edited by Zing
      Re: Can't connect to wifi with RP4.
      I share my problem expecting it can help to identify a solution for all.
      config :
      • Raspberry 4,
      • Recalbox 8.02 (image form Raspberry PU Imager V1.7.1)
      Impossible to connect (no ip, status not connected)
      it can find and see the SSID
      The signal is strong
      I don't have any problem with the same equipment same place and a Recalbox 7.2.2 or earlier.
      My box is a french livebox with 2,4 and 5 GHz
      • kiki_tls
        This post is deleted!
          Scavy Global moderator @kiki_tls last edited by
          @kiki_tls hello
          Your card is out of a case ?
          Wifi is activated ? Your SSID does not appear ?
          Your wifi module may be broken..?
