    Generic PS4 Controller Wont Sync After Reboot Help
    GamePad/GPIO/USB encoder
    generic ps4 wont sync reboot help
    • sismo99
      sismo99 last edited by
      Hi I have a Generic PS4 controller, that wor great with the console and i synched it with my RBPi 3B+ and it works the light of the controller turns blue and evertyhing Ok BUUUUT, when o Reboot or restart recalbox the controller wont connect and i have to pair it again and i tried a lot of things but nothing seems to work
      the funny thing it is taht yesterday it worked all day i rebooted and tur off/onn the console and keep connected but today it was imposibble and i really dont remember have done anything diferent but yesterday worked today not
      i tried qith Recalbox 7.2.2, 8.0 and 8.0.2 and currentlyu have the latest 8.0.2 and nothing
      I test it on RBPi 3B+ and my RBPi 4 8GB an no work i also searched a lot but doesn seem yto be a solution at least piblished i hope you can help my or maybe show me the correct way to do it
      Finally i must say that the problem is only with te GENERIC controller the original PS4 Work great but i have 2 genircs so i want to be able to use them
      Sorry for my english and hope you can help me i want to upload avideo but i dont know is i am allowed to put a you tube link
      Thanks a Lot
        Zing Global moderator Translator @sismo99 last edited by
        @sismo99 Have you tried a factory reset?
        You will not lose any personal information, but you will lose your custom settings.
        • sismo99
          thanks for your answer yes i alredy do that in fact i even make several fresh installs and nothing so i cant make it work
          just for checking i nstalled retropie and there it worked great i prefer recalbox but i try it just to check that the problem is softwre hope you can help me
