    [BATCH] Scrape your roms on your PC - fastscraper
    Community projects
    multiconsole scraper fastscraper
    37
    221
    286015
    • IceLancer
      IceLancer last edited by IceLancer
      Hey!
      I have constant crash when attempting to scrape
      Every single time it will crash on 5 specific games in my mame game list.
      Here is data
      2017/11/08 00:10:18 arcade srcs:
      2017/11/08 00:10:18 console srcs: ss,gdb,ovgdb
      2017/11/08 00:10:18 INFO: Checking for new hash.csv.
      2017/11/08 00:10:19 INFO: hash.csv "d9eedf6e622a8ab6a1a14486bb90ffb8" up to date.
      2017/11/08 00:10:20 INFO: Checking for new OpenVGDB.
      2017/11/08 00:10:20 INFO: Upgrading OpenGDB: -> "bc42a41ec8f627815ea1dee9dfcd9514".
      2017/11/08 00:10:22 INFO: Upgrade Complete.
      2017/11/08 00:10:22 INFO: Starting: test\columns.zip
      panic: runtime error: invalid memory address or nil pointer dereference
      [signal 0xc0000005 code=0x0 addr=0x28 pc=0x709c45]
      goroutine 65 [running]:
      github.com/sselph/scraper/rom.getImage(0x9470c0, 0xc042047d80, 0x0, 0x0, 0xc04293a1e0, 0x16, 0x190, 0x0, 0x0, 0x0)
      /home/sselph/go/src/github.com/sselph/scraper/rom/rom.go:366 +0xf5
      github.com/sselph/scraper/rom.(*ROM).XML(0xc042e2ba80, 0x9470c0, 0xc042047d80, 0xc042049400, 0x6, 0x8, 0xc04203fb10)
      /home/sselph/go/src/github.com/sselph/scraper/rom/rom.go:495 +0x62d
      main.worker(0x9470c0, 0xc042047d80, 0xc042940180, 0x6, 0x8, 0xc042049400, 0xc04203fb10, 0xc04301a480, 0xc04301a4e0, 0xc042280a80)
      /home/sselph/go/src/github.com/sselph/scraper/scraper.go:140 +0x4e8
      created by main.crawlROMs
      /home/sselph/go/src/github.com/sselph/scraper/scraper.go:223 +0x66b
      Start : 0:10:18.64
      Finish : 0:10:23.40
      Duration : 00:00:04,76
      There is nothing in the folder except one single game. Columns.zip
      And as i said regular scrape without ur batch file will go throu that without error.
      Do u know whats causing this?
      Ok i went and tested each line separately it seems that -download_marquees="true" is causing the crash.. i cant tell why..
      ok Sorry it has nothing to do with ur batch, i have posted issue on sselph git
        paradadf Staff @IceLancer last edited by
        @icelancer yep, exactly. That's something sselph needs to look into.
        • IceLancer
          Add an option to turn off scraper.exe autoupdate. its easy to compile from git with go. And bat keeps bringing old exe instead of my new compiled one. Had to manually cut the code for update.
            @icelancer have you tried increasing scraper.exe version number before compiling? I‘d need to check that. If you can, please open an issue about this on github do I don‘t forget about it, please.
            IceLancer 2 Replies Last reply Reply Quote 0
            • IceLancer
              IceLancer @paradadf last edited by IceLancer
              @paradadf Should i have? I just compiled from git
              BTW , answer me this if u can , thanks.
              Is it possible to tell batch when asking for system name , to give him folder name with space ?
              I am in process of sorting rom folder to their original names and i am stuck with this bat now.
              i tried :
              Sega Dreamcast
              "Sega Dreamcast"
              'Sega Dreamcast'
              it keeps finding Sega OR Dreamcast, as not found. But not Sega Dreamcast
              IceLancer 1 Reply Last reply Reply Quote 0
              • IceLancer
                IceLancer @IceLancer last edited by
                @icelancer meh 😞 not even "all" can see folders with spaces..
                for /F "delims=" %f in ('dir /B /A:D') do set system=!system! %f
                Lists folders properly:
                set system=!system! Sega Dreamcast
                Why isnt it finding Sega Dreamcast then?
                • IceLancer
                  This post is deleted!
                    @icelancer EmulationStation doesn‘t have system names containing more than one word (or spaces), so I didn‘t bother taking that case into account. Do you really need it? Why don‘t you use folder names like ES?
                    About your first question... could you send me your compiled version so I can test it?
                    Maybe changing == by GEQ in the update check might be enough.
                    • IceLancer
                      @paradadf Sorry but yeah, i am kinda heavy on heaving everything sorted top notch. Making rom folder names to their specs is priority to me. I already spent a week modifing all database to match it.
                      it also makes all 3 frontend systems working in sync
                      BUT its not priority for you at all. I found workaround for batch fastscraper by doing dirty hack to it.
                      here is scraper
                      https://mega.nz/#!MxQ0HJQa!h6RU6cHjV83F8T7d7wPDOfFJdwo_P8t0EKz-ruVDa4c
                      it reads :
                      fastscraper ver. 14.09.2017
                      paradadf 2 Replies Last reply Reply Quote 0
                        @icelancer I‘ll see what I can do. Hopefully I find some time to test one thing before sselph uploads a newer version 🙂
                        I meant the scrapers version, not fastscrapers version. But don‘t worry... your compiled version should be enough.
                          @icelancer there is something weird with your compiled version. When running a batch with the command scraper.exe -version you should get something like v1.4.4 and not an empty string. Moreover, your scraper.exe is over 8 mb while the one sselph offers is only 5,5 mb. I´m not sure where in his code the versioning is being made, but you´ll need at least the same version number as the latest one available on github for the update script to be skipped. Erasing that part of the code is easier (if you really need it) instead of adding a switch.
                          About your folder names with spaces... I´ll look into it when I have time.
                          • IceLancer
                            @paradadf I don't know why the discrepancy in size. Its clean Git compile.
                            I tried scraper -version
                            doesnt print anything.
                            Btw i noticed its not just me who is insisting on up to the code rom folder names. Every Hyperspin user insists on the same as well, i didnt knew that. But when i think more on it i honestly do not see any legitimate reason for ES to use manufactured names like they do.Its pure chaos and a mess.
                            P.S
                            I also noticed havoc when collections got support in ES. People even made topic to organize "new unified" names for them. Its hilarious.
                            • RandySlim76
                              RandySlim76 @Javier Sandoval last edited by RandySlim76
                              @javier-sandoval Can I inquire what exactly was changed in the fastscraper.bat file to fix the Windows 7 64bit issue you were having?
                              I am having the exact same issues. Thank you.
                              Also if an Admin or if anyone knows how or what he did to get fastscraper.bat to get past this registry error I would deeply appreciate it. Thank you.
                                paradadf Staff @RandySlim76 last edited by
                                @randyslim76 for the interface language, I added this line which might help you if the pc language isn‘t recognized:
                                https://github.com/paradadf/recaltools/blob/master/fastscraper/fastscraper.bat#L11
                                RandySlim76 1 Reply Last reply Reply Quote 0
                                • RandySlim76
                                  RandySlim76 @paradadf last edited by RandySlim76
                                  @paradadf I changed the language to en on mine and the language error is gone. I'm proud you figured that part out. Now the registry error from what I read above when you helped out the chap to figure out his 64bit issues he said he deleted and or edited several lines of the code. Do you have any idea what these two gentlemen did to make it work without the error? Thanks in advance. 0_1516838330062_IMG_20180124_175839.jpg
                                  Also I haven't had a chance to try it but would this be the section that is causing the registry error?
                                  These are the changes he said he made to get the batch working.
                                    paradadf Staff @RandySlim76 last edited by paradadf
                                    @randyslim76 probably... if you can‘t automatically overcome that point, try setting/forcing the arch variable one line after the code you just posted.
                                    If afterwards the download, extraction, etc isn‘t working, just download the corresponding version from sselph scraper github page and place the scraper.exe nect to the fastscraper.bat.
                                    • RandySlim76
                                      @paradadf I greatly appreciate all of the extensive help, but I'm not good at coding. So could you please explain that simpler terms Thank you.
                                        @randyslim76 I‘ll try to make some sort of debug batch for people having problems with the registry and powershell
                                        • RandySlim76
                                          @paradadf Thank you very much. I truly appreciate it.
                                            @randyslim76 just download this simple batch and run it on your pc:
                                            fastscraper_debug.bat (batch for direct download)
                                            fastscraper_debug.bat (batch code)
                                            show me the output afterwards.
                                            RandySlim76 2 Replies Last reply Reply Quote 0
                                            101.0k
