    PS/2 iPac
    Emulator Arcade/PC/Console
    ps2 ipac
    • steveloaf
      steveloaf last edited by
      Before I start I want to make it clear that I have gone through the Wiki and understand how to set up the iPac creating the files in the recordbox2jstick directory etc. Here is the issue I have run into. I am using an older PS/2 iPac board and have seen many people say they made it work. What I haven't seen is anyone who started Recalbox and only had the PS/2 converter but not the iPac show up. This is what I get:
      ls -lR /dev/input
      /dev/input:
      total 0
      drwxr-xr-x 2 root root 140 Jan 16 23:13 by-id
      drwxr-xr-x 2 root root 180 Jan 16 23:13 by-path
      crw-rw---- 1 root input 13, 64 Jan 1 1980 event0
      crw-rw---- 1 root input 13, 65 Jan 1 1980 event1
      crw-rw---- 1 root input 13, 66 Jan 1 1980 event2
      crw-rw---- 1 root input 13, 67 Jan 16 23:13 event3
      crw-rw---- 1 root input 13, 68 Jan 16 23:13 event4
      crw-rw---- 1 root input 13, 69 Jan 16 23:13 event5
      crw-rw---- 1 root input 13, 70 Jan 16 23:13 event6
      crw-rw---- 1 root input 13, 63 Jan 1 1980 mice
      crw-rw---- 1 root input 13, 32 Jan 16 23:13 mouse0
      /dev/input/by-id:
      total 0
      lrwxrwxrwx 1 root root 9 Jan 16 23:13 usb-CHESEN_PS2_to_USB_Converter-event-if01 -> ../event6
      lrwxrwxrwx 1 root root 9 Jan 16 23:13 usb-CHESEN_PS2_to_USB_Converter-event-kbd -> ../event3
      lrwxrwxrwx 1 root root 9 Jan 16 23:13 usb-CHESEN_PS2_to_USB_Converter-if01-event-mouse -> ../event4
      lrwxrwxrwx 1 root root 9 Jan 16 23:13 usb-CHESEN_PS2_to_USB_Converter-if01-mouse -> ../mouse0
      lrwxrwxrwx 1 root root 9 Jan 1 1980 usb-Microsoft_Wired_Keyboard_400-event-kbd -> ../event0
      /dev/input/by-path:
      total 0
      lrwxrwxrwx 1 root root 9 Jan 1 1980 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.1:1.0-event-kbd -> ../event0
      lrwxrwxrwx 1 root root 9 Jan 16 23:13 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.0-event-kbd -> ../event3
      lrwxrwxrwx 1 root root 9 Jan 16 23:13 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.1-event -> ../event6
      lrwxrwxrwx 1 root root 9 Jan 16 23:13 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.1-event-mouse -> ../event4
      lrwxrwxrwx 1 root root 9 Jan 16 23:13 platform-fd500000.pcie-pci-0000:01:00.0-usb-0:1.4:1.1-mouse -> ../mouse0
      lrwxrwxrwx 1 root root 9 Jan 1 1980 platform-fef00700.hdmi-event -> ../event1
      lrwxrwxrwx 1 root root 9 Jan 1 1980 platform-fef05700.hdmi-event -> ../event2
      /dev/input/by-id:
      -bash: /dev/input/by-id:: No such file or directory
      total 0
      -bash: total: command not found
      -bash: lrwxrwxrwx: command not found
      /dev/input/by-path:
      -bash: /dev/input/by-path:: No such file or directory
      total 0
      I even tried creating files in the xarcade2jstick directory using the names of the USB converter which I hardly thought would do anything but it was an act of a desperate man. Any ideas would be appreciated.
        Zing Global moderator Translator @steveloaf last edited by
        @steveloaf See if this helps:
        https://forum.recalbox.com/topic/24477/tuto-config-i-pac-ultimlate-2-ou-4-j-pac-et-mini-pac
