    Nintendo DS and 3ds emu/Pi 4B 2GB Recalbox 8
    Emulator Arcade/PC/Console
    nintendo 3ds emupi 2gb recalbox
    14751
    • Diebstahl
      Diebstahl last edited by
      Hello everybody!
      I am quiet new to Pi and I read there is the possibility to play DS and 3DS titles on Recalbox.
      I found all other rom folders for my roms but no DS or 3DS folders.
      What is my problem? 🙂
      Thanks a lot in advance.
      • Pitch64
        Pitch64 Staff last edited by
        There is no DS on Pi4 and no 3DS at all everywhere.
        You can check the available system on this page 🙂 https://wiki.recalbox.com/en/hardware-compatibility/emulators-compatibility
        Next release? Soonâ„¢
        • Diebstahl
          Diebstahl last edited by Diebstahl
          I just saw the systems on this page:
          https://www.recalbox.com/de/database/
          Okay. It's a pity but isn't changeable I think.
          Thanks
          E: Will it be implemented in the future?
          If running n64 on pi I think ds and 3ds should also
          be possible. But I don't have a clue 😀
          • Pitch64
            3DS is too much recent to be considered as retro.
            Diebstahl 1 Reply Last reply Reply Quote 0
            • Diebstahl
              Diebstahl @Pitch64 last edited by Diebstahl
              @pitch64 But DS is possible down the line?
              SilverGreen93 1 Reply Last reply Reply Quote 0
              • Pitch64
                Not on Pi4, PC only, check the link I gave you earlier, you have all systems available for any compatible board listed.
                • Diebstahl
                  @pitch64 Thanks for the info
                  • SilverGreen93
                    SilverGreen93 @Diebstahl last edited by
                    @Diebstahl There is DS emulation on Batocera on Pi 4 and Pi 5 using DraStic emulator. It works quite nice.
                    Recalbox should add DraStic as well to make it work.
