    Recalbox 8 on Asus Eee PC - Question 4
    recalbox asus eee
    • BitFunX
      BitFunX Banned last edited by
      Recalbox 8 tells me I need a "SCPH1001.bin" Rom for the Sony Playstation Emulator.
      These Rom must have the MD5-Checksum of
      DC2B9BF8DA62EC93E868CFD29F0D067D
      or
      924E392ED05558FFDB115408C263DCCF
      I've got the a few Roms from different Sources with both of the right MD5-Checksums but Recalbox 8 didn't recognize all of them and tells me the Rom is missing.
      I tried everything, even rename the Rom from "SCPH1001.bin" to "scph1001.bin" but nothing works.
      So tell me, why isn't Recalbox axecpting these Rom and telling me it's not there even if it had the correct MD5-Cecksum.
      And yes. before somebody asks:
      The Rom is placed in the right folder -> recalbox\share\bios
        Zing Global moderator Translator @BitFunX last edited by
        @bitfunx If you have the BIOS "scph1001.bin" correctly renamed as requested, and with the correct MD5 in the correct folder, Recalbox will recognize it.
        In the built-in BIOS checker, you have a thumb of what color for that BIOS?
        BitFunX 1 Reply Last reply Reply Quote 0
        • BitFunX
          BitFunX Banned @Zing last edited by
          @zing
          Ok, fixed the Problem.
          Put the Bios named "scph1001.bin" in the "Bios"-Folder.
          In the "Main-Menu" I go to "Bios Checking", Select the Bios and press the "Start"-Button on my Gamepad.
          Recalbox checks the Bios and says it's OK now.
