    Mega Drive/Genesis not working.
    mega drivegenesis working
    • ryouga
      ryouga last edited by
      I am using a GPI case, the latest version of the image and a pi zero 2
      Every other emulator seems to work, but Mega Drive/Genesis games don't show, only the preinstalled games.
      I tried hiding the preinstalled games, showing hidden files, renaming the folder from megadrive to genesis and nothing.
      As I say every other emulator works fine.
      I wrote the files directly to sd card from Windows rather than use wireless.
      The preinstalled games work so it cannot be an emualtor issue.
      Even tried reflashing the image even formatting the sd card fully.
      Using a Samsung 256gb micro sd (not a fake one)
      Previously to using recalbox I used supremegpi on a Zero W OG model and Mega Drive worked on that so I doubt its the SD card itself.
      airdream Zing 2 Replies Last reply Reply Quote 0
      • airdream
        airdream Theme moderator @ryouga last edited by
        @ryouga
        It's recommanded to use No-Intro romset for Megadrive.
        Maybe your gamelist file is corrupted...
        Wich emulator (core) do you use for Megadrive?
          Zing Global moderator Translator @ryouga last edited by
          @ryouga
          https://forum.recalbox.com/topic/25504/recalbox-8-0-electron-no-mega-drive-games-showing-up/4
          • ryouga
            Thanks, so its an issue then, yes I use no intro in md format.
