    Bluetooth disable ertm not working
    GamePad/GPIO/USB encoder
    xbox bluetooth raspberry 3 b+ help me
    7
    25
    10437
    • rebok232
      rebok232 last edited by
      I have xbox one and series x controller and i want connect this controllers wirlessly using bluetooth on raspberry pi 3 b+ I'm trying change disable ertm to Y but always after reboot i have N
      • Pitch64
        Pitch64 Staff last edited by
        Those controllers are not compatibles yet, it needs xpadneo which is not included yet.
        Next release? Soon™
        charger rebok232 2 Replies Last reply Reply Quote 0
        • charger
          charger Banned @Pitch64 last edited by
          @pitch64
          Just to ask, but is there a bluetooth gamepad on the face of the earth that always reconnects if it comes out of the power saving state? Because apparently you always have to physically turn the RPI4 back on otherwise it won't reconnect anymore ...
          davidb2111 1 Reply Last reply Reply Quote 0
          • davidb2111
            davidb2111 Staff @charger last edited by
            @charger said in Bluetooth disable ertm not working:
            @pitch64
            I've got an 8bitdo SN30, PS3 and PS4 that work flawlessly. Microsoft gamepad support is more or less stable...
            Even Nintendo Switch joycons connect back without issue.
            charger 2 Replies Last reply Reply Quote 0
            • charger
              charger Banned @davidb2111 last edited by
              @davidb2111 said in Bluetooth disable ertm not working:
              @pitch64
              I have sf30pro + (fw updated), rpi4 and recalbox 8 stable.
              Everytime sf30 goes into power saving, is impossibile to reconnect again without restart rpi4.
              I don’t understand how is it possibile that you haven’t any issue…is sf30pro different from sn30?
              • charger
                @davidb2111 just bought sn30, but on rpi4 and recalbox 8, situation doesn’t changed. Randomly, after some games, is impossibile to reconnect ANY controller (virtual, bt, cabled) if primary is turned off or is in power saving mode.
                  Zing Global moderator Translator @charger last edited by
                  @charger Please make sure it is not firmware related as described here:
                  https://forum.recalbox.com/topic/25352/recalbox-8-0-beta/41
                  charger 1 Reply Last reply Reply Quote 0
                  • charger
                    charger Banned @Zing last edited by charger
                    @zing said in Bluetooth disable ertm not working:
                    For sure is not, cause it affect even virtual controller and wired controller. Even virtual gamepad doesn't works after first controller was turned off.
                    • rebok232
                      rebok232 @Pitch64 last edited by
                      @pitch64 It is posible to install xpadneo?
                      Pitch64 davidb2111 2 Replies Last reply Reply Quote 0
                      • Pitch64
                        Pitch64 Staff @rebok232 last edited by
                        @rebok232 It won't work - https://gitlab.com/recalbox/recalbox/-/issues/1609
                        Next release? Soon™
                        • davidb2111
                          davidb2111 Staff @rebok232 last edited by
                          Hi @rebok232
                          Unfortunately, we had to postpone xpadneo. This needs testing and nobody in the dev team nor beta team's got a compatible gamepad.
                          David
                          xtc0r 1 Reply Last reply Reply Quote 0
                            @charger
                            For sure is not
                            And did you at least test it?
                            • charger
                              @zing Sure!
                              • davidb2111
                                Hi @charger
                                Is your RPI4 in a case? We have users that reported bluetooth/wifi issues with some of them.
                                David
                                • charger
                                  charger Banned @davidb2111 last edited by charger
                                  @davidb2111 Everything works well with batocera, everything doesn't works (but the first load) on recalbox.
                                  So the problem IS recalbox.
                                  Again: when gamepad is disconnect, every next controller with every connection doesn't works: bt, usb, virtual gamepad, everything doesn't works anymore.
                                  Just formatted and reinstaller from scratch three times...no solutions, but is here to see, I cannot understand how you don't be able to reproduce this issue.
                                  • play one game
                                  • exit with start+select
                                  • turn off BT gamepad
                                  • turn on BT again
                                  • CRASH -> every controller doesn't works anymore, doesn't matter connection type: usb, bt, virtual
                                  • rebok232
                                    It is posible to use xboxdrv?
                                    • MatsO
                                      MatsO last edited by
                                      I had the same problem, then I changed to system driver instead of auto in controller settings then I rebooted now it works for me.
                                      I have a rpi4 with recalbox 8 and a PS3 controller
                                      Hope it works for someone else👍
                                      • charger
                                        charger Banned @MatsO last edited by
                                        @matso yours controller is wireless? Can you try to disconnect and reconnect after exiting game? Does it works again?
                                        MatsO 1 Reply Last reply Reply Quote 0
                                        • MatsO
                                          MatsO @charger last edited by
                                          @charger yes it is connected via Bluetooth, and before I changed the driver I had the exakt issu as described here. Now I can connect and disconnect and connect again and working👍
                                          charger 2 Replies Last reply Reply Quote 1
                                          • charger
                                            @matso could you please tell me exact model of your gamepad?
