    Recalbox 8.0: (ERROR) : [SDL2] Fatal error initializing SDL2
    recalbox 8.0 [sdl2] fatal initializing sdl2
    6957
    • fh1105
      fh1105 @davidb2111 last edited by
      @davidb2111 said in Recalbox 8.0: (ERROR) : [SDL2] Fatal error initializing SDL2:
      cat /sys/class/drm/card*/modes
      It's a HDMI-connected HD screen – normal 'office type'.
      returns nothing at all.
      fh1105 1 Reply Last reply Reply Quote 0
      • fh1105
        fh1105 @fh1105 last edited by
        But here's me exploring that directory:
        # pwd
        /sys/class/drm
        # ls
        card0           card0-HDMI-A-1  renderD128      version
        # cd card0-HDMI-A-1
        # ls
        device     edid       modes      status     uevent
        dpms       enabled    power      subsystem
        # cd modes
        -bash: cd: modes: Not a directory
        # ls
        # cat modes
        # cd ..
        # ls
        # cd card0
        # ls
        card0-HDMI-A-1  device          subsystem
        dev             power           uevent
        (modes in card0-HDMI1-A-1 is empty)
        davidb2111 1 Reply Last reply Reply Quote 0
        • fh1105
          By the way: amazing support, @davidb2111! Thank you very much!!
          davidb2111 1 Reply Last reply Reply Quote 1
          • davidb2111
            davidb2111 Staff @fh1105 last edited by
            Hi @fh1105
            Seems edid does not report modes. Could you force the mode within /boot/recalbox-user-config.txt.
            hdmi_group=1
            hdmi_mode=X
            where X should be:
            • 16 for 1080p
            • 4 for 720p
            • 1 for VGA mode (640x480, as a fallback)
            Once started, if still no display, try adding this setting:
            hdmi_ignore_edid=0xa5000080
            Hope this help.
            • davidb2111
              davidb2111 Staff @fh1105 last edited by davidb2111
              @fh1105
              Also, do you know the resolution of your TV?
              • fh1105
                Hello!
                Just a brief update, as I solved it by simply removing everything from my GPIO ports, and wiring my arcade buttons to a
                Zero Delay Arcade USB Encoder
                – which then connects to the RPi's USB ports.
                All good now! Thank you, and keep it up!
                Fabian
