    Overscan does not work on Recalbox 8
    overscan does recalbox
    • Wizzard
      Wizzard last edited by
      Hi, friends, I had the problem that the composite out did not work on Rpi3b, but it was solved by some workaround:
      https://forum.recalbox.com/topic/25440/emulationstation-does-not-start-on-rpi3b-on-rb8-using-composite
      Now I have the problem that I cannot enable overscan for my beloved CRT TV. I need to use it cause the picture is bigger than my screen, lol, so I used it it 7.2.2 and it worked perfectly. Now when I enable it in the advanced menu, it just does not do anything, the picture is still way bigger than my CRT display. Any idea how to fix it? I downgraded to 7.2.2 for now, cause I really need it.
      Thanks for any idea.
      • Wizzard
        I opened an issue here https://gitlab.com/recalbox/recalbox/-/issues/2061
