    Recalbox 8.0 - power switch led still not working and share folder not automaticaly recognize with windows
    recalbox 8.0 switch led still share automaticaly recognize windows
    • dolpingates
      dolpingates last edited by
      hello , this morning i try new recalbox 8.0 fresh install and new sdcard on Raspberrty pi3B+
      1. power switch led
        " system.power.switch=PIN356PUSHRESET # https://wiki.recalbox.com/en/tutorials/others/add-on-off-button-to-your-recalbox"
        stil not working on 7.2.2 works so well ( i have report on beta too)
        (manual and webmanager )
      2. share folder not detect automacticaly on windows, need change drive letter on disk management , after that is show.
      3. change audio output on webmanager not working
        ^_^ thanks you sorry for my bad english
        Zing Global moderator Translator @dolpingates last edited by
        @dolpingates
        1. power switch led
        Please check this part calmly, confirm that the physical connection is correct, you may have miswired at some point, or be using the wrong type of button.
        1. share folder not detect automacticaly on windows, need change drive letter on disk management , after that is show.
        It's a Windows bug that can't be fixed in Recalbox.
        dolpingates 1 Reply Last reply Reply Quote 0
        • dolpingates
          dolpingates @Zing last edited by dolpingates
          @zing thanks for replay.
          1. cable is good bcause i have another sdcard with recalbox 7.22 is works shutdown , reset and led works. recalbox 8.0 on another sdcard. i just switch the sd card and not work on recalbox 8.
          2. but on recalbox 7.22 share folder show without need to disk management.
          ^^ sorry for my bad english ^^ thank you
            @dolpingates
            See if what is reported in this other post is related:
            https://forum.recalbox.com/topic/25442/boîtier-argon-pi4-recalbox-8-0
            1. but on recalbox 7.22 share folder show without need to disk management.
            Not for everyone, it's just a coincidence that it didn't happen to you in version 7.2.2, other users had the same problem in the previous version... It's a bug that happens randomly (not sure why).
            I've had this bug on other devices that didn't have any OS installed (external hard drive and USB stick), I'm sure it's not a Recalbox bug. On my USB stick for example, most of the time that I formated it, I had no problem, but once in a while it happens (and I only use it to transport files).
            Don't worry, I don't speak English either. 😬
            • dolpingates
              @zing ok thank you ^_^ i will stick on 7.22 until more stable version 8 realease
              this my build
