    Kodi on GPi Build 8.0.0
    MediaCenter & Dualboot
    kodi gpi build 8.0.0
    • menaceone
      menaceone last edited by
      Hello,
      I installed the new 8.0.0 Beta on my GPi Case with RPi Zero 2.
      Emulation works fine and its awesome.
      However I would love to view TV on my handheld via Kodi.
      Per default Kodi is not enabled on the GPi Build.
      Editing recalbox.conf and switch kodi.enabled=1 does not enable Kodi in Settings.
      Is there another way to enable Kodi on GPi or is it simply not possible?
      Greetings
      digitaLumberjack 1 Reply Last reply Reply Quote 0
      • digitaLumberjack
        digitaLumberjack Staff @menaceone last edited by
        @menaceone hello, sadly we could not continue to support kodi on GPI case, the version we compile is not compatible anymore with the drivers we use in the RPIZERO2 + GPICase image.
        Sorry !
        menaceone 1 Reply Last reply Reply Quote 1
        • menaceone
          menaceone @digitaLumberjack last edited by
          @digitalumberjack
          ah thanks for the reply, so I don't have to tinker around anymore.
          Playing retro games is better than TV anyway 😉
