    Gpi case, use d-pad as analog
    GamePad/GPIO/USB encoder
    gpio analog joy
    2187
    • Anklum
      Anklum last edited by
      Hi,
      I have a gpi case with the new raspberry zero 2W
      It’s great some dreamcast games can run now but most of them use an analog pad and the d-pad is quite useless (crazy taxi, star wars racer, …)
      The gpi case only have a d-pad so I tried to remap settings and use the d-pad as an analog but it doesn’t seem to work.
      How could I do?
      Thanks
      Anklum 1 Reply Last reply Reply Quote 0
      • Anklum
        Anklum @Anklum last edited by
        I can see a solution exists to use the other d-pad mode ( change with select and left or up) on retropie but how could I use it on recalbox ?
        https://www.reddit.com/r/retroflag_gpi/comments/c1psvj/dpad_not_working_in_pcsxrearmed_and_gpsp/ergdcal/
        • minibreak
          minibreak last edited by
          Meme problème pour moi. Comment faire pour jouer a des jeux comme Rayman the great escape (qui passe tres bien d ailleurs)? Comment configurer le pad ?
          minibreak 1 Reply Last reply Reply Quote 0
          • minibreak
            minibreak @minibreak last edited by
            same problem here, cannot play Rayman great escape on dreamcast due to to that.
            Any idea apart from pairing a controller with bluetooth?
            • Bkg2k
              Bkg2k Staff @Anklum last edited by
              @anklum It's working everywhere. This is a feature from the GPI firmware.
              • minibreak
                minibreak @Bkg2k last edited by
                @bkg2k indeed @Anklum , the select + left/up trick works although it required several trials. you need to use it when setting your controller in the menu and then switch from d pad to analog using selct + up/left when running the game depending if you are playing or in menu(rayman on dreamcast as example)
