    Back to Recalbox main menu impossible with N64
    Emulator Arcade/PC/Console
    recalbox main
    • Fabox
      Fabox last edited by
      Hello everyone,
      After months without using my recalbox, I turned it back on to reinstall everything so it is now in 7.2.2Reloaded.
      I installed some roms without any issues and the return to the recalbox main menu for snes or other emulators poses no problem except for N64 it's impossible to return to the main menu with the combination of button of the joystick (PS4 controller), I have to turn my rapsberry pi3 off and on again.
      Do you know why?
      Thank you for your answers.
        Zing Global moderator Translator @Fabox last edited by
        @fabox
        When you reinstalled everything, how did you copy your files from the previous version?
        Right is just copying ROMS/BIOS/Saves.
        If you copied some configuration file together, this could be the problem, I recommend you try a reset to factory settings (available through the menu), you won't lose any personal files, but you will lose your custom settings.
        You can do this through Recalbox Manager, when really needed:
        https://wiki.recalbox.com/en/tutorials/system/access/recalbox-manager-web-interface
        except for N64
        What emulator are you using?
        Have you tried with another N64 emulator?
        Fabox 1 Reply Last reply Reply Quote 0
        • Fabox
          Fabox @Zing last edited by
          @zing Hi Zing, i did a factory reset and the issue is the same.
          I will reinstall of the recalbox software and tell if the incident is resolved.
          So, for the installation i follow the one who is on recalbox website. 7.2.2 reloaded. I didn't change the N64 emulator.
            @fabox
            Test with another emulator to see if the problem persists.
            I recommend that you test the 8.0 beta version, and if you encounter a problem, post the problem in the specific post:
            https://forum.recalbox.com/topic/25351/recalbox-8-0-beta
