    PS3 gamepad not working wireless before Pi3b 7.2.2 upgrade
    GamePad/GPIO/USB encoder
    ps3 gamepad wireless before pi3b 7.2.2 upgrade
    • alyado
      alyado last edited by
      Dear fellows,
      I am new here, but read all posts before writing this one. I have a Pi3b and 4 ps3 controllers (2 originals, 2 first line).
      All my gamepads were working fine, wireless, with oficial driver, UNTIL I updated the system to 7.2.2. Now, all gamepads work fine but only WIRED.
      In order to test, I have downloaded latest version of recalbox to install at another microSd, which I did. Same thing with this brand and fresh new system: all gamepads working fine wired, but not wireless.
      Have you heard about a ps3 gamepad driver problem with the new update?
      Thank you very much for your time and help.
      • alyado
        Just to make my words clear, the best title for topic would be "PS3 gamepad not working wireless AFTER Pi3b 7.2.2 update"
        The gamepads were working fine wireless before the update. After that, not working wireless, only wired.
          Zing Global moderator Translator @alyado last edited by
          @alyado Have you ever tried to change the driver via menu?
          alyado 1 Reply Last reply Reply Quote 0
          • alyado
            alyado @Zing last edited by
            @zing Yes, I have tryed to change through the recalbox manager. I tryed all three drivers, and nothing worked. I reset gamepads, stop emulestation, etc. No combination worked. But I have solved: I found a 7.0 oficial rom ate the internet archive and flashed with etcher.
            In the end, installing previous version worked fine for me.
              @alyado Try version 8.0 beta and report issues on this topic:
              https://forum.recalbox.com/topic/25351/recalbox-8-0-beta
