    Recalbox 7.2.2 TV CRT (Pi4)
    Recalbox geral
    recalbox 7.2.2 crt
    • fneto4
      fneto4 last edited by fneto4
      I'm trying to configure a recalbox 7.2.2 image on a Toshiba 29" CRt TV using rbp4. I used the p2 composite cable settings but the image was pretty bad. I did a test without modifying the config.txt file, putting an HDMI converter to VGA and the image was also very bad, could anyone help?
      I know there are two files I need to change:
      config.txt
      recalbox-user-config.txt
        Zing Global moderator Translator @fneto4 last edited by
        @fneto4
        https://forum.recalbox.com/topic/24091/composite-not-working-on-7-2
        fneto4 1 Reply Last reply Reply Quote 0
        • fneto4
          fneto4 @Zing last edited by
          @zing I did it the same way but the image was bad.
            @fneto4 About using a CRT TV via composite cable, I just answered another post with a similar situation, please check:
            https://forum.recalbox.com/topic/25248/can-not-use-the-composite-output-in-recalbox-7-2-2-on-my-raspberry-pi-4b
            HDMI
            Have you tested your Rpi on another TV without an adapter?
            Can you test with another adapter?
            Are you testing with the correct HDMI port on the RPi4?
            Have you tested with another HDMI cable? There are several versions of HDMI cable, not to mention the quality of the cable...
            Have you checked if it's not some setting on the TV?
            Signal converters usually don't bring the expected result, they don't always manage to make the ideal communication between the RPi and the TV (since they make a conversion).
            A signal converter is literally like an automatic translator: sometimes the translation is so mechanical that you can't understand it even after the information is in your native language.
            In short, the converter needs to correctly identify your TV's EDID, and convert that to RPi. When the converter can't even recognize the edid, the whole conversion goes bad, so one possibility you have is to force an edid configuration manually, as per the options mentioned in the official raspberry documentation:
            https://www.raspberrypi.com/documentation/computers/config_txt.html#hdmi_ignore_edid
            There are some users who claim that a DVI adapter works better, but I've never used it either, and there are many different makes and models, so I can't say:
            https://forum.recalbox.com/topic/24295/message-hors-de-portée-écran/2
            Generally speaking, video adapters are not a good idea, use them only if they are the last option. And unfortunately, we don't have a lot of user reports showing which makes and models are working, and without those user comments, we don't know either.
