    Dreamcast load issue
    Emulator Arcade/PC/Console
    dreamcast issue
    2738
    • SsssQ
      SsssQ last edited by SsssQ
      after perfect crt setup I decided to play some dreamcast games. I had some gd-rom rips taken from cdromance and one ripped from my own gd-rom. here's the list of games i've got: sonic adventure 2(Echelon. my gd rom rip), puyo puyo fever(DCRES, CDromance, chd), puyo puyo 4(CDromance chd). I started puyo puyo fever, but when audio surround logo apperars I saw some graphical issues(some unknown shards of color yellow and green) next the most of the game's intro was missing textures and title screen was black. when I tried to go into menu the emulator crashed. after this I tried sonic adventure 2. the game functions as normal but when it tries to load a level it freezes, but you can exit from it. And puyo puyo 4 was played as normal(no issuses). Please fix the issue, who also got the same problem write in comments. I've got RPI3B+.
      SsssQ Zing 2 Replies Last reply Reply Quote 0
      • SsssQ
        SsssQ @SsssQ last edited by
        @ssssq also got enter key issue(but that's not your problemđŸ€Ł )
        RustyMG 1 Reply Last reply Reply Quote 0
        • RustyMG
          RustyMG @SsssQ last edited by RustyMG
          @ssssq you DO realise that N64, Dreamcast, and PSP emulation on the Pi is still far from perfect, and LOTS of games still do not even load, play properly, or crash?
          This is nothing to do with Recalbox, but, the actual emulators.
          With each update, more and more games do work (look at how many now work compared to just 2 years ago), but, you have unrealistic expectations.
          Also, for all 3 systems mentioned, you really are best to have a Pi4.
          Sinclair ZX Spectrum 48k "dead flesh" keyboard, Commodore 64, Amiga A500, Amiga A1200, CD32, PC Engine, PS1, PS2, PSP, Nintendo DS, Dreamcast, Wii, XBox 360, Xbox One-X, Pi2, Pi3, Pi4 owner, ARRM contributor ( http://jujuvincebros.fr/wiki/arrm/doku.php ).
            Zing Global moderator Translator @SsssQ last edited by
            @ssssq
            I've got RPI3B+.
            As already mentioned, N64, Dreamcast and PSP are consoles that don't have perfectly optimized emulators for RPI, the best emulation happens in RPi4 (which is the most powerful), but even so users use overclocking to have a more fluid performance.
            The graphical problems you have are normal, as the emulator was configured to have the best possible performance, and that's why it was necessary to give up the graphical quality: it's better to have a game that works, than a beautiful game that you can't play .
            You can try overclocking if you're interested (and only if you have a good cooling system - never overclock without heatsink and cooler), but I don't know how feasible it is for you, you'll get a performance boost, but still it won't be a perfect emulation.
            Se a minha resposta foi Ăștil, por favor, dĂȘ um voto positivo, clicando na seta para cima logo abaixo da resposta, ao lado de "citar".
            SsssQ 1 Reply Last reply Reply Quote 0
            • SsssQ
              SsssQ @Zing last edited by
              @zing when I was on HDMI it was running p e r f e c t. No lags. No anomalies. But when I switched to crt the troubles started.
                @ssssq
                First: It would save time if you had said this information from the beginning, please specify as much information as possible so that someone can help you correctly.
                So the problem is probably the fact that you configure it in CRT, possibly you need to change the Dreamcast videomode, and once again I would point out that Dreamcast/N64/PSP are emulators that have these emulation difficulties.
                Let's go to some questions:
                • Do you have your BIOS perfectly recognized in the built-in BIOS checker (green thumbs)?
                • Have you already tested it with the two emulators: Flycast and Reicast?
                • You can test the same game with an iso redump as mentioned in the documentation?
                In addition, there is the question of the videomode I mentioned, the information appears in the recalbox.conf file:
                ## Dreamcast emulator
                ## Like N64, such a CPU intensive emulator needs a small resolution
                ## Consider DMT 4 HDMI (640*480) or DMT 9 HDMI (800*600). If you have a black screen on dreamcast, try DMT 9 HDMI here
                ;dreamcast.videomode=DMT 4 HDMI
                The official Flycast documentation specifies some resolutions:
                https://docs.libretro.com/library/flycast/#core-options
                Reicast's official documentation specifies some possible video configurations:
                https://reicast.com/guide/
                Maybe this will help:
                https://forum.recalbox.com/topic/23950/7-2-mode-non-optimum/10
                • SsssQ
                  @Zing anyways, recalbox sux, it did eat my entire 16gb sd card
                  davidb2111 1 Reply Last reply Reply Quote 0
                  • davidb2111
                    davidb2111 Staff @SsssQ last edited by
                    @SsssQ said in Dreamcast load issue:
                    @SsssQ , I really don't understand what's the problem.. Recalbox does not "eat" disk space for pleasure.
                    Without more information, we could not help you.
