    Issue starting any PSX games on Recalbox x86
    Emulator Arcade/PC/Console
    issue starting recalbox x86
    2309
    • Infiltraitor
      Infiltraitor last edited by Infiltraitor
      Hi,
      Just started joining the forum. I'm having difficulty having answers from the Discord Channel, I figured it's best to ask it here instead.
      Here is my problem with my setup. I have a 2007 PC running Recalbox x86 version.
      I have good gameplay running previous generation systems, up to Nintendo64. Unfortunately only the PSX emulation I'm having issues with.
      I have done the following:
      • secured the required BIOS set.
      • re-aquired a clean copy from a reliable source.
      • tested Bin & Cue format and it fails
      • converted to eboot, it still fails
      This 2007 machine can run PSX easily with windowsXP installed with ePSXe with no issues. On Recalbox I can't seem to have it working at all.
      All games will try to boot, and displays and error code after:
      It appears your game didn't start at all!
      A couple of things could cause this:
      • Bad ROM
      • Missing/bad mandatory BIOS files
      • Missing/bad optional BIOS files (but required for this game)
      Thanks to anyone able to help me out with this.
      • digitaLumberjack
        Hi o/
        Is it a 32bit cpu ?
        Can you try the 64bit image if not ?
        Infiltraitor 1 Reply Last reply Reply Quote 0
        • Infiltraitor
          Infiltraitor @digitaLumberjack last edited by
          @digitalumberjack
          Hi, thanks for noticing my post. The CPU it has is capable with 64bit windows, but I can only have x86 to work on it. I have tried the x64, but just before installation can start or even load a live session; it halts with continues error that I can't understand.
          I'm now able to use the x86, does this mean PSX is not supported for the x86 setup?
          digitaLumberjack 1 Reply Last reply Reply Quote 0
          • digitaLumberjack
            digitaLumberjack Staff @Infiltraitor last edited by
            @infiltraitor did you try to change the default emulator / core ?
            • Infiltraitor
              @digitalumberjack
              To be honest, I dont know how to do that. I was actually in the process of doing it. Both for PSX and SNES if possible.
              • digitaLumberjack
                @infiltraitor
                START -> ADVANCED SETTINGS -> ADVANCED EMULATOR CONFIGURATION
                Infiltraitor 2 Replies Last reply Reply Quote 0
                • Infiltraitor
                  @digitalumberjack
                  Thank you, I'll do that now.
                  • Infiltraitor
                    @digitalumberjack said in Issue starting any PSX games on Recalbox x86:
                    @infiltraitor
                    You sir have solved my concern in a mater of minutes. Thank you for your support and expertise.
